removing o2 sensor
do you mean, its hanging from a firewall? thats how it was in my gsr. i unplugged my secondary o2 from the cat and then had to unplug it from inside the car behind the headunit console. hope this helps.
How about the front O2 sensor in the manifold ? Mines seems to be recessed thru the manifold heat plate. Do you need a special recessed wrench or do you have to unbolt the manifold cover ....the unscrew ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alotawatts »</TD></TR><TR><TD CLASS="quote">How about the front O2 sensor in the manifold ? Mines seems to be recessed thru the manifold heat plate. Do you need a special recessed wrench or do you have to unbolt the manifold cover ....the unscrew ?</TD></TR></TABLE>
Should be a couple bolts to remove the manifold cover, then you can get it off with an 02 sensor wrench.
p.b.k
Jun 10, 2010 06:42 PM
arielb1
Apr 5, 2006 05:59 AM
2000blacksi
Dec 26, 2002 04:42 PM
