Tial 38mm WG, green spring 3PSI!! WTF
Old Oct 22, 2004 | 05:14 AM
Boosted2K's Avatar
Default Tial 38mm WG, green spring 3PSI!! WTF
I used to get about 5-6 psi off the WG spring, now I only see 3-4. If I set the Greddy Spec II to 7psi I get 6psi.
So could it still be a boost leak if the boost controller gets me the correct boost level according to what I set it at???
I thought the green spring was like 9ish???
Are the springs interchangable between WG sizes???
Old Oct 22, 2004 | 06:50 AM
m R g S r's Avatar
Default Re: Tial 38mm WG, green spring 3PSI!! WTF (Boosted2K)
Sounds like a boost leak.
Old Oct 22, 2004 | 08:49 AM
Boosted2K's Avatar
Default Re: Tial 38mm WG, green spring 3PSI!! WTF (m R g S r)
Thanks for the reply, I figured just as well. Just ordered a bunch of T-bolts from Stan, so hopefully that will fix it.
It's just the boost controler thing has me confused, if I set it to 7psi, and it was a boost leak I would think that I would only still be seeing 5-6psi.
I'll figure it out, I always do
Old Oct 22, 2004 | 08:52 AM
B18C1CYA's Avatar
how are you able to set it to a psi value? mine only displays duty cycle
Old Oct 22, 2004 | 08:55 AM
accordfreak's Avatar
def a boost leak.. i had the same problem except i was only getting 1psi. first i used a bike pump to locate the leak but the leak was so big i had to use a air compressor to find it. it was leaking through my stupid EGR which i plugged up after i found it.
home depot material
91integraLSVTEC
Oct 21, 2009 11:09 AM
RTW DC2R
Mar 24, 2006 06:33 PM
SPOOLINmatt
Apr 16, 2005 10:13 PM
95gsrturbo
Dec 4, 2003 03:48 PM
zojirushi
Jan 23, 2002 04:42 PM
