Changing Transmission Fluid
I know how to drain it through the drain plug and i know what the filler plug is. My first question 1.) what does vss stand for? I read posts taht say fill the transmission fluid through the vss. and my second question 2.) when i fill it through the filler hole, how do i get it in there?i have seen on other posts that people say to use a pump. what kind of pump? any info would be helpful.
VSS- vechicle speed sensor
the fill plug is right above the drain, drain used a 3/8 rachet, fill is a 17mm bolt
everyone does it a different way, i wont take the vss out to fill, i use a funnel and a small clear hose , make sure the car is even/level. put the hose in the fill hole and fill untill it starts to drip out, usually about 2 quarts.
Also there is a valve on the top of the tranny with a rubber plug on it, its a vent i take it off so it will drain and fill quicker.
hope that helps you
hope that helps you
well prob a bit less than 3 since i poured in 3 and let some of it drain out from the filler hole. I dunno ive always talked to gsr guys and they have always told me 3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">i believe a gsr tranny calls for 2.1 quarts. atleast this was what i read somewhere when i was refilling my tranny with fluid.</TD></TR></TABLE>
Maybe so... i remember pouring in 3 and just letting all the excess drip out of the fill hole
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">make sure the car is even/level.</TD></TR></TABLE>
I filled my tranny during the end of the swap so the car was jacked up in the front. I drove it and shifting wasn't smooth. Later, refilled the tranny while the car is on the ground and I was able to add another half quart.
I got a pump at a local parts store (Autozone or Orielly). Its like 2-3 bucks. It makes it a lot easier to fill the tranny.
I filled my tranny during the end of the swap so the car was jacked up in the front. I drove it and shifting wasn't smooth. Later, refilled the tranny while the car is on the ground and I was able to add another half quart.I got a pump at a local parts store (Autozone or Orielly). Its like 2-3 bucks. It makes it a lot easier to fill the tranny.
luv2boost
Aug 8, 2007 10:06 PM
eL
10
Jan 30, 2005 04:02 PM
