Wastegate & Blowof Valve
I was told that you only needed one or the other. Is This true. Or do you need a wategate and a blowof valve.
My turbo has a wastegate actcuator on it but i planed on taking that off..If i do then will i need the wastegate. Or will the blow off valve work?
Srry for the NEWBlike question!
BOV's and wastegates are 2 totally different things..
Wastegate controls how much psi the turbo boosts
BOV lets out the air from the turbo after the throttle body has closed to prevent compressor surge.
If u take off the wastegate on the turbo u would have to an external wastegate..which would mean u would have to either but a new turbo manifold made with an external wastegate flange or modify ur existing manifold to work with the external wastegate...
abmerop18
Jan 27, 2005 08:05 AM
