i need some help please!
my check engine light is comming on and its giving me the code of 13 and 43 dont know where to go to check to see what that means but its giving me 1 long 3 short and then 4 long 3 short so i assume its 13 and 43 correct me if im wrong but i think im right?
i tried to find a chart on http://www.hondata.com but couldnt find much please help me out i dont wanna pay a honda tech mad $$ for him to tell me thanks alot guys and awesome place
Check out this: http://www.hybrid.honda-perf.org/tech/codes.html
There is no code 43 in pre obd ecus.
But the code thirteen is the egr lift sensor EDIT check that I read it off the page wrong it is the Baro sensor. I would suggest getting a helms manual to help troubleshoot the codes.
[Modified by 91civic, 5:04 AM 12/19/2001]
ok i found out where the codes are im having a 43 Fuel supply system and 13 BARO - atmospheric pressure sensor so what do i do next? how much does a atmospheric pressure sensor coast and how hard are they to change? and what about the fuel supply system should i change fuels filter what else? also my exahust (spelling) smells really bad.........lol so i know there is a fuel prob but what it is is what i cant figure out!
thanks alot.
thanks alot.
I read in another post you have a zc, so you have a OBD0 ecu. There is no code 43 on your ecu. OBD0 ecus only had 20 codes. So the 43 might be a code 4 and a code 3.
damn i dont know all i know is it gave me 4 long and 3 short then pause no light for a while and gave me a 1 long and 3 short? like i said i have no idea what the hell this means.............
thanks for the help man!
diyeealooen
Oct 11, 2010 05:34 AM
deercanbrack
May 14, 2008 03:49 PM
saunders400
Aug 13, 2007 09:13 AM
