VIBRATING NOISE IN H22A/EG NEED HELP BAD!
B A N N E D
Wuts up guys i have a eg with h22a in it and i jsut recently put a m2b4 tranny in yesterday and i go and take it out and i feel this vibrating movement coming from the left side of my car in the front under accleration......so i change my driver side axle(by the way im using 90-93 integra axles with accord intermediate shaft im pretty sure there are no part numbers on the shaft to tell but i dont think the integra axles will fight into a prelude intermediate shaft) and it is still making this vibrating movement. Could this be a wheel bearing? are my axles wrong someone please help me out
how old are you motor mounts?
was there any shudder before you put in the m2b4?
doubt its wheel bearing...
did you feel it coming from the left side of the car because you are sitting on the left side?
are you using the prelude passenger inner axle hub in conjunction with the teg shaft and outer hub?
Passenger side axle IS too long, if you have the M2B4 LSD tranny. Use a 89 Integra passenger side axle with Prelude/Accord inner joint. You can leave the driverside & intermediate shaft alone.
