obd1 motor opposed too....
Old Dec 18, 2001 | 07:17 PM
ArchAngel Sabastian's Avatar
New User
Default obd1 motor opposed too....
hey does anyone know or have an idea
if you took a obd1 h22
and then a obd2 h22 with a harness converting to obd1
if there would be a power diff?
Old Dec 18, 2001 | 07:19 PM
SOHCArchangel's Avatar
Default Re: obd1 motor opposed too.... (Sabastian)
man the obd-II motor is a weak block, its cast open deck, the H22a1 is not its closed deck
Old Dec 18, 2001 | 07:44 PM
New User
Default Re: obd1 motor opposed too.... (SOHCkordVTEC)
what is open closed deck?
Old Dec 18, 2001 | 09:12 PM
tonydatyga's Avatar
search saves time and you don't look silly
Old Dec 19, 2001 | 03:35 AM
urbanlegend21's Avatar
New User
Default Re: obd1 motor opposed too.... (tonydatyga)
this is actually a question that has not been discussed alot in this forum....
OBDI -allows for more modification to fuel/air setups
OBDII- tighter emissions restrictions that does not set itself well for modifcation
Old Dec 19, 2001 | 05:24 AM
New User
actually do me a favor and dont tell me to search for things that arent there the only thing refering to an open deck is an s2000 post.
[Modified by Sabastian, 6:25 AM 12/19/2001]
Old Dec 19, 2001 | 05:35 AM
New User
and i answer my own questions:
Open Deck - Any block in which around the cylnder bore there is deep ring around the bore's i believe the rings are called water jackets but im not sure
Closed Deck - Is just a block with out the water jackets around the bore.
Ill post a pic if anyone whos learning wants one
Old Dec 19, 2001 | 02:32 PM
4doorH22's Avatar
Default Re: obd1 motor opposed too.... (urbanlegend21)
Yeap, but I wonder what those OBD II to I harnesses do. I doubt they can make an OBD II ECU as mod-friendly as an OBD I one.
Old Dec 19, 2001 | 03:12 PM
New User
Default Re: obd1 motor opposed too.... (4doorH22)
i thought the whole idea behind the harness was that you originally obd2 car now used and obd1 ECU rendering the obd2 sensors non active such alowing better performance for mods..
Old Dec 19, 2001 | 03:26 PM
4doorH22's Avatar
Oh oh oh I didn't realize an OBD I ECU was used. I thought it somehow used an OBD II ECU and motor and made it function like OBD I... or something.
cheffery
Mar 27, 2011 06:31 AM
JJGL-EF90
Feb 17, 2010 08:07 AM
boostin92hatch
Sep 27, 2007 11:59 AM
rippinitup01
Jun 19, 2007 06:11 AM
B18C1 '96 Coupe
May 21, 2003 02:25 PM
