Advantage to not runnin valve stem seals?
Old Oct 21, 2004 | 09:52 AM
tremor86's Avatar
Default Advantage to not runnin valve stem seals?
I read in one post that someone wasnt running valve stem seals. What is the point to this? Wouldnt it let alot more oil into the head then into the cylinders?
Old Oct 21, 2004 | 10:42 AM
Finland's Avatar
Default Re: Advantage to not runnin valve stem seals? (tremor86)
The advantage would be that you would blind anyone behind you with a huge cloud of smoke...
Old Oct 21, 2004 | 10:46 AM
RyanEJ8's Avatar
Won't work. I'd like to see this post.
Old Oct 21, 2004 | 01:44 PM
Turbowa's Avatar
Let me know if you get it to work. That way I can take out my buddy's bad valve stem seals and he can save a couple hundred bucks on not replacing them. j/k
Old Oct 21, 2004 | 01:51 PM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tremor86 &raquo;</TD></TR><TR><TD CLASS="quote">I read in one post that someone wasnt running valve stem seals. What is the point to this? Wouldnt it let alot more oil into the head then into the cylinders?</TD></TR></TABLE>
are you sure he just didn't cut his valve stems...like the Type R's are factory done?
Old Oct 21, 2004 | 01:53 PM
non-VTEC's Avatar
we have this engine builders book for the GM 2.2L ecotec 4cyl engine at work and inside it details all the parts and assembly procedures they used to make the 900+hp turbo drag engine.
they specifically said that they run no valve stem seals in that particular head so they can get maximum valve lift without the retainer hitting and crushing the valve seal
again.......this is there all out 900+hp drag engine which probably gets re-built ever few passes down the strip.....so there is absolutely no sense in doing such a thing for a street car. don't even think about it......
Old Oct 21, 2004 | 01:57 PM
Joseph Davis's Avatar
Default Re: Advantage to not runnin valve stem seals? (Turbowa)
Lots of older engines don't run valvestem seals, and got away with it just fine. Most the old TRs I played with used shitty umbrella seals, you pulled the valvecover and they were either fubar or a previous owner/mechanic hadn't bothered to replace them. On those engines it didn't matter much, aside from a plume of blue smoke on startup. I have seen a few TR straight 6 that had the tops of their valveguides machines to accept a GM seal, the guides on my 2.5 are set up for it but I never installed them.
But, I digress. I think you most definitely want valvestem seals in a Honda application, especially forced induction.
Old Oct 21, 2004 | 02:04 PM
Hbgsr's Avatar
Default Re: Advantage to not runnin valve stem seals? (J. Davis)
Hone each guide to each valve and it will work.
Old Oct 21, 2004 | 02:18 PM
8200RPM's Avatar
local hippie
Default Re: Advantage to not runnin valve stem seals? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
again.......this is there all out 900+hp drag engine which probably gets re-built ever few passes down the strip.....so there is absolutely no sense in doing such a thing for a street car. don't even think about it......</TD></TR></TABLE>
^^ I agree. Seals are there for a reason.
Old Oct 22, 2004 | 08:02 AM
tremor86's Avatar
Default Re: Advantage to not runnin valve stem seals? (8200RPM)
It was on some thread about "earl" cheating or some ****... dont know anything about that situation. Just curious...
Old Oct 22, 2004 | 08:31 AM
earl's Avatar
Some very high performance engines can get away with no valve seals but each valve guide has to be custom fit clearance wise.
The other thread was about putting nitromathane into your oil, pulling off the valve seals, letting the oil and nitro drip into the cylinder. To me, this is an ignorant idea on a 4 stroke engine but maybe it works in a 2 stroke engine somehow. No experience with that.
Old Oct 22, 2004 | 10:39 AM
Default Re: Advantage to not runnin valve stem seals? (earl)
Nitromethane is a handy thing to blend with your water and surfactant in an electronic water injection setup - no more complaints about displacing volume better filled with fuel/oxygen. Defintely something you want to precisely meter, and not drip around guides, IMO.
Sorry for the OT blurb.
lsvtechatch92
Dec 23, 2007 02:02 PM
si937
Jul 25, 2006 02:18 PM
huepowered
Apr 4, 2006 12:10 PM
Layziebtnh055
Apr 11, 2004 07:41 AM
