Heater/cooling system problems
Old Oct 21, 2004 | 09:32 AM
JDM EJ1 95's Avatar
Default Heater/cooling system problems
itll warm up fine at idle sitting in my garage but when i drive... right back down to cold.. it wasnt the thermostat bc i replaced it... (that was when i had my dseries stil) and after the swap it still does the same thing (JDM LS Motor) im stumped.. i think it has something to do with my heater core bc my heat doesnt work for **** it always blows cold or luke warm air.... i need heat.. winters a commin
Problems: engine wont stay at a high enough temperature and heat doesnt blow hot..
Old Oct 21, 2004 | 10:00 AM
JDM EJ1 95's Avatar
anyone?? bump?
Old Oct 21, 2004 | 10:58 AM
JDM EJ1 95's Avatar
bump
Old Oct 21, 2004 | 12:41 PM
JDM EJ1 95's Avatar
bump i need heat
Old Oct 21, 2004 | 12:57 PM
01SSAP1's Avatar
Default Re: Heater/cooling system problems (JDM EJ1 95)
Check Thermostat
Can do this by taking it out and putting it in a bowl of steaming hot water to see if it expands or contracts
Make sure you have fresh properly mixed Coolant. 50% Water and 50%
Antifreeze
Make sure fins on Radiator are ok. If there all fins are broken then the rad may need to be replaced.
Otherwise take it to a shop...........
Old Oct 21, 2004 | 08:00 PM
JDM EJ1 95's Avatar
check. check. chekc... its not any of those problems.. 1. the radiator is in brand new condion.. 2. it happend when i had my Dseries before and after a new thermostat.
3. mix is fine.. its been fine for both the engines and it still persists...
right now im thinking its the heater core... because if i turn my climate control on cold and put it on full blast the air blows really hard .. but when i switch it over to hot the air comes out at like half the speed it did when its at cold... so im thinking its clogged or somethigns goin on
Old Oct 22, 2004 | 07:05 AM
JDM EJ1 95's Avatar
plz help bump
Old Oct 22, 2004 | 07:39 AM
Mac2118's Avatar
Default Re: (JDM EJ1 95)
I kind of have the same problem, I took my car to a honda shop last night to get this checked out. I had to have the thermostat replaced (the guy told me that the ones from AZ and AAP suck.. oh well) but it might be the water pump by the firewall..
hope that helps a bit..
Old Oct 22, 2004 | 08:27 AM
JDM EJ1 95's Avatar
doubtits the water pump or anything within the engine itself bc ive had 2 engines and both have the exact same problem
Old Oct 22, 2004 | 08:48 AM
01SSAP1's Avatar
Probably the Heater Core then
If it is clogged then you won't get heat.
You don't smell Antifreeze coming through your vents that would indicate a leak in the core?
I don't know how difficult it is to change a heater core in a Honda as I have owned 3 hondas and never had that problem.
Went through 2 heater cores in my 87 Pontiac 6000.
If you have checked everything else then that is probably where I would focus at this point.
Old Oct 22, 2004 | 08:51 AM
JDM EJ1 95's Avatar
i dont get why the engines not staying warm though.. im pretty sure my heat not workign is the heater problem.. but my engine just wont stay warm when tis below 45 degrees outside
Old Oct 22, 2004 | 08:54 AM
01SSAP1's Avatar
Well the Heater core is part of your Coolant Cirulation system.
So if it is clogged then coolant is not making a full trip through the entire system and therefore the thermostat may be incorrectly reading the coolant temperture.
I don't know I'm not a mechanic lol
Old Oct 22, 2004 | 09:31 AM
JDM EJ1 95's Avatar
sounds fair enough.. i appreciate your advice.. thanks
Old Oct 22, 2004 | 11:59 AM
JDM EJ1 95's Avatar
bump
Old Oct 22, 2004 | 02:11 PM
JDM EJ1 95's Avatar
bizzump
Old Oct 22, 2004 | 04:33 PM
JDM EJ1 95's Avatar
BUUUUUUUUUUUUUMP
Old Oct 23, 2004 | 10:24 AM
JDM EJ1 95's Avatar
i need to know
Old Oct 23, 2004 | 07:57 PM
JDM EJ1 95's Avatar
C O M E O N
Old Oct 23, 2004 | 08:02 PM
f1z1c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 &raquo;</TD></TR><TR><TD CLASS="quote">i dont get why the engines not staying warm though.. im pretty sure my heat not workign is the heater problem.. but my engine just wont stay warm when tis below 45 degrees outside</TD></TR></TABLE>
Thats pretty cold right there, you might need to go richer on anti-freeze, like 60-40 or whatever the bottle recommends for super cold places. You checked for proper fan function and fan switch, because if the switch is stuck on the on position, your engine will get too cold, or too cold for fuel efficiency and emissions. And also how about the viscosity on the engine oil?
Old Oct 24, 2004 | 05:45 PM
JDM EJ1 95's Avatar
its got nothing to do with anything on the engine.. bc ive had 2 engines and its done the same exact thing for both.. im putting a 50-50 mix of antifreeze/water and im running 5w30 Synthetic blend.
Old Oct 24, 2004 | 07:53 PM
JDM EJ1 95's Avatar
tried bleeding the cooling system today for the hell of it... no avail
Old Oct 25, 2004 | 11:08 AM
JDM EJ1 95's Avatar
up
Old Oct 25, 2004 | 11:24 AM
TekSI's Avatar
does the engine stay hot and no heat comes out? from what i read, sounds like you turn the heat on, the engine cools rapidly, doesn't sound right or possible. if no hot air comes out, but the engine doesn't overheat, i'd say the ventilation system is clogged.
has the car sat still for a long time? if so, a mouse or other small animal may have stuffed the vents with stuff, building a nest-like thing. happens alot around here, not sure bout where you are
Old Oct 25, 2004 | 11:52 AM
dantastic's Avatar
try bypassing you heater core if you think its the problem.
Old Oct 25, 2004 | 12:01 PM
monicle's Avatar
so it heats up fine at an idle but gets cool when youre driving? what thermostat do you have in there? you might change it to a high temp one so that it doesnt open up till a higher temp. Aslo is it a stock radiator?
