has anyone who used a bigger crank ( stroker crank) been able to retain the oil squirters ?
Old Oct 21, 2004 | 08:33 AM
JBBNJ609's Avatar
Default has anyone who used a bigger crank ( stroker crank) been able to retain the oil squirters ?
im looking at going with a bigger crank in my 84mm bore block, but i want to have oil squirters because this is a daily driver
Old Nov 3, 2004 | 10:56 PM
JBBNJ609's Avatar
Default Re: has anyone who used a bigger crank ( stroker crank) been able to retain the oil squirters ? (ja
bump
Old Nov 10, 2004 | 05:59 AM
JBBNJ609's Avatar
bump
Old Nov 10, 2004 | 06:25 AM
dragonz04's Avatar
i think you should post what block you have, ie gsr or ls or b20 block. if you use the squirters in a b20 block w/ ls crank i heard some people chipping the squirters. i'm about to use a gsr crank in a b20 block and I think i'll be safe from chipping the squirters. if you are getting forged pistons, i don't think you should be worried of the squirters unless they were stock pistons.
Old Nov 10, 2004 | 07:17 AM
Power Rev Racing's Avatar
I put a LS crank in a GSR block and was able to keep the Oil Squitters. They needed to be notched alittle bit though.
Old Nov 10, 2004 | 08:09 AM
Used2beAb16's Avatar
If you are going with a stroked crank i am going to assume that u are going to be running forged rods and pistons. If this is the case then u dont need the squirters. The squirters are for cooling the pistons, but forged materials have a much better tolerance of heat and also have better cooling properties.
Unless u are going to run and OEM pistons i wouldn't concern yourself with squirters, and even then i wouldnt make it a big deal.
Old Nov 10, 2004 | 10:12 AM
West Werks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragonz04 &raquo;</TD></TR><TR><TD CLASS="quote">i think you should post what block you have, ie gsr or ls or b20 block. if you use the squirters in a b20 block w/ ls crank i heard some people chipping the squirters. i'm about to use a gsr crank in a b20 block and I think i'll be safe from chipping the squirters. if you are getting forged pistons, i don't think you should be worried of the squirters unless they were stock pistons.</TD></TR></TABLE>
Well from the jist of it, hes talking about oil squirters. Only vtec engines have oil squirters?
And in your case, a gs-r crank would work fine in a b20 block because there are no oil squirters in non-vtec blocks (from the factory).
Old Nov 10, 2004 | 10:50 AM
a gsr crank would work fine in a b20 but it wouldnt be a 2liter anymore. He wants to put in a bigger crank not a smaller one.
Old Nov 10, 2004 | 10:55 AM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Used2beAb16 &raquo;</TD></TR><TR><TD CLASS="quote">If you are going with a stroked crank i am going to assume that u are going to be running forged rods and pistons. If this is the case then u dont need the squirters. The squirters are for cooling the pistons, but forged materials have a much better tolerance of heat and also have better cooling properties.
Exactly, Jay, you are running forged pistons, correct? just cap off the squirters so you wont have to worry about bending/grinding.
Old Nov 10, 2004 | 02:41 PM
JBBNJ609's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">Exactly, Jay, you are running forged pistons, correct? just cap off the squirters so you wont have to worry about bending/grinding.</TD></TR></TABLE>
yea forged rods, pistons and LS crank
im ognna see if my builder will set the squirters back so they dont touch . . if he can , just in case
Old Nov 10, 2004 | 03:34 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason bouchard &raquo;</TD></TR><TR><TD CLASS="quote">
im ognna see if my builder will set the squirters back so they dont touch . . if he can , just in case </TD></TR></TABLE>
if you are using forged pistons, cap them off. Less oil sticking to the bottom of the pistons = lighter pistons.
Old Nov 11, 2004 | 11:40 AM
that is interesting i never thought of it from that aspect, i always just said it was uneccesary
DA9tothewheel
Engine Machining & Assembly
May 23, 2016 09:25 AM
DA9tothewheel
Dec 11, 2015 07:00 AM
94dxeh2
Jan 11, 2010 08:26 PM
EG6 Love
Jan 8, 2009 05:53 AM
K20 EG
Jun 24, 2003 09:22 AM
