My windows suck!! Please help me out, would ya?
Old Dec 18, 2001 | 05:27 PM
Erik95LS's Avatar
Default My windows suck!! Please help me out, would ya?
Alright, here's the problem. I was cleaning my car the other day and i go to put the windows up to windex them, and my passenger side window does not work. I checked both switches, niether one would do it. i checked the fuses and the relays and they were fine. So I began taking the passenger door apart. I checked all the conections and wires and everything apears to be fine. I tested both switches and they both work perfectly. I also found out that the motor works fine, and there is power going to the right-hand door. Everything, besides the passenger side switch, is working fine on the left-hand side too. Also the wires from the passenger side switch to the motor are working fine. My only guess is that it's somehow the switch mechanically isn't working, but still passed the continuity test.
Does anyone have any ideas or experience with this? please help me if you can, it really sucks not having a window, or a door panel on that side. TIA
Old Dec 18, 2001 | 06:27 PM
Chris's Avatar
Default Re: My windows suck!! Please help me out, would ya? (DOHC ACURA)
LMFAO!!!
On the drivers side window switch, just above the window switches, there is a rocker switch that, for child protection, turns OFF the passenger side window.
Old Dec 18, 2001 | 06:30 PM
aLmoSt-vtec's Avatar
New User
Default Re: My windows suck!! Please help me out, would ya? (Chris)
this has got to be the toughest technical question yet here at HT......
buahahahahahah.....
Old Dec 18, 2001 | 09:52 PM
Hapa DC5's Avatar
Default Re: My windows suck!! Please help me out, would ya? (aLmoSt-vtec)
lol that was great...
Old Dec 19, 2001 | 03:03 AM
smeister's Avatar
lol come on guys we all have our brain farts
Old Dec 19, 2001 | 11:55 AM
Erik95LS's Avatar
Default you people really suck sometimes
hey *******, i'm not an idiot. I know about the child lock. i've checked every possible thing i can think of. I know i didn't mention the lock in my original post because i can't think of anyone who would be ignorant enough to go through all of that, without checking that out first. The main reason i came to this board was because of the lack of *********, so let's keep it that way alright.
now, does anyone want to actually try and give me a hand and give me an actual suggestion?
[Modified by DOHC ACURA, 8:56 PM 12/19/2001]
Old Dec 19, 2001 | 12:00 PM
VTechie's Avatar
Default Re: you people really suck sometimes (DOHC ACURA)
All right, enough name calling, eh?
About your window problem: You say that the motor works. Is it actually turning when you hit the switch? If that's the case, I would look for a broken drive gear. If the motor is turning and it is in fact trying to move the window, but the window won't budge, then look at the slides to make sure everything is lubricated and aligned.
Old Dec 19, 2001 | 12:21 PM
Erik95LS's Avatar
the motor doesn't turn when the switch is engaged. the motor can be turned on and it actually works and runs the window up and down, when the switch is bypassed, but only from the right side. still the switch somehow passed the continuity test. i'm completely stumped.
and as to the name calling thing. I'm not really mad at anyone. it just amazes me sometimes howa good 5-8 different people will reply without even trying to give a helpful suggestion. anyway thanks. keep em coming.
Old Dec 19, 2001 | 12:26 PM
Chris's Avatar
Default Re: (DOHC ACURA)
I know it was blatently obvious to some, but it might not have been to others.
Check the voltage coming out of the switch with the switch in the on position, that will tell you if the swich is bad.
Old Dec 19, 2001 | 01:07 PM
Isaac's Avatar
New User
Wow, you're a rookie and you darest insultest a mod(est)? Tuff Bizznitchest doggest. Oh darn, that's too bad about your windows, umm, I sure hope you get them fixed.
Old Dec 19, 2001 | 06:11 PM
Erik95LS's Avatar
Default Re: (Chris)
oh sorry dude that wasn't aimed at you. you actually gave a suggestion. i just hate it when other people don't even put out any effort to help someone, when that is the main reason this place is here.
Old Dec 19, 2001 | 06:23 PM
Chris's Avatar
No worries.
How about that Voltage measurement??
Old Dec 19, 2001 | 06:39 PM
Erik95LS's Avatar
Default Re: (Chris)
i haven't had time to check that and i won't be able to for awhile. I'm leaving town tomorrow, for christmas. i ran a continuity test on the switch and that checked out ok, but i honestly don't know. i'll look into the voltage thing when i get back. thanks for your polite help and concern though
Chrisxnj
10
Dec 6, 2016 01:21 PM
einzelherz
Dec 16, 2011 02:58 PM
gliaZeD
Aug 19, 2011 11:15 AM
Singlecam4dr
Mar 17, 2010 02:51 PM
sjbmx
Aug 9, 2009 05:38 AM
