LOOK QUIck Is this the Flywheel Bolts?
Old Oct 21, 2004 | 12:14 AM
TurboTeG4's Avatar
Default LOOK QUIck Is this the Flywheel Bolts?
http://cgi.ebay.com/ebaymotors...sting
Is those 8 bolts the flywheel bolts for a 94 GSR, If so what the hell kind of bolts is that what size??
Old Oct 21, 2004 | 02:32 AM
Sack Master's Avatar
Default Re: LOOK QUIck Is this the Flywheel Bolts? (TurboTeG4)
I don't know the size off hand but those look like flywheel and clutch bolts to me. Please phrase that so we can understand what you are asking.
Old Oct 21, 2004 | 03:13 AM
hondaguyef's Avatar
Default Re: LOOK QUIck Is this the Flywheel Bolts? (Sack Master)
Yes those are the (8) flywheel bolts and (6) pressure plate bolts.
Phil
Old Oct 21, 2004 | 04:27 AM
eLUDEnu
Guest
Posts: n/a
Default Re: LOOK QUIck Is this the Flywheel Bolts? (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Yes those are the (8) flywheel bolts and (6) pressure plate bolts.
Phil</TD></TR></TABLE>
but you really cant tell from the pic if they are for a gsr or not.
Old Oct 21, 2004 | 07:21 AM
mmuller's Avatar
Mad Scientist
Default Re: LOOK QUIck Is this the Flywheel Bolts? (eLUDEnu)
flywheel= 12x 1 mm
clutch= 8x 1.25 mm
those look like the right ones
Old Oct 21, 2004 | 08:16 AM
96MidoriHatch's Avatar
Default Re: LOOK QUIck Is this the Flywheel Bolts? (mmuller)
if its for a gsr then you need 9 pressure plate bolts
Old Oct 21, 2004 | 10:35 AM
vtec69's Avatar
the bigger ones are the flywheels and the smaller ones are the clutch ones
Old Oct 21, 2004 | 10:58 AM
IN VTEC's Avatar
Those bolts look like shorter flexplate bolts rather than flywheel bolts.
If you want to see a picture, I can show you.
You only need (6) pressure plate bolts if you're using a Honda flywheel. That part is fine, unless you're using an aftermarket flywheel that typically takes (9).
Old Oct 21, 2004 | 11:58 AM
Default Re: LOOK QUIck Is this the Flywheel Bolts? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
You only need (6) pressure plate bolts if you're using a Honda flywheel. That part is fine, unless you're using an aftermarket flywheel that typically takes (9).</TD></TR></TABLE>
your right i forgot about that
tech410
Aug 10, 2010 05:31 AM
EG2Driver
Oct 7, 2006 07:50 PM
kuja
Jul 5, 2005 08:51 PM
PatrickGSR94
Apr 18, 2003 06:00 AM
garados
Nov 1, 2002 08:43 PM
