i took out my SOHC head (top)
hmm i took out my D16z6 upper head (camshaft, springs, valves..etc are still inside)...and they hella dirty with nasty oil smell....
what should i buy to clean the head good...anyone have done it before please let me know thanx
thats if the head is on the car....or do you mean you took off the valvecover??? if so put it back on and run seafoam through the car , do a search on how to use it.
well i took off the valvecover out then the head.....the head itseld still have camshaft, valves, and springs...inside....
oh yeah where can i get those seafoam...and should i take springs...valves and camshaft off the head and get them clean? or what
well if im going to clean the bottom block can i still use seafoam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr »</TD></TR><TR><TD CLASS="quote">oh yeah where can i get those seafoam...</TD></TR></TABLE>
search...its been covered numerous times
lol, does'nt seafoam need heat to work, hence why you need the car running/warmed up. Just bring it to a machine shop, have them steam clean it for 25-35 bucks. Comes out brand new. done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yanta »</TD></TR><TR><TD CLASS="quote"> Just bring it to a machine shop, have them steam clean it for 25-35 bucks. Comes out brand new. done.</TD></TR></TABLE>
I got mine pressure tested and cleaned for 30.00
I found this thread to very informative, may help you. https://honda-tech.com/zerothre...97412
You will need to but your motor back together first!
my engine is out of the car already...too hard to find a steam or hot tank around my area....and dann...i just did porting on the IM inlet ports...larger and smoother look nice at hell
my engine is out of the car already...too hard to find a steam or hot tank around my area....and dann...i just did porting on the IM inlet ports...larger and smoother look nice at hell</TD></TR></TABLE>
Start calling machine shops, they almost always have them
my engine is out of the car already...too hard to find a steam or hot tank around my area....and dann...i just did porting on the IM inlet ports...larger and smoother look nice at hell</TD></TR></TABLE>Start calling machine shops, they almost always have them
