H22A and H23 wiring harness difference?
Old Oct 20, 2004 | 08:40 PM
boosted_teg93's Avatar
Default H22A and H23 wiring harness difference?
i swapped a H22A in for a H23 in a '92 and the harness i recieved with the H22 is all cut up, can i just plug in the v-tec ecu into the non v-tec harness or what should i do? please help.
Old Oct 20, 2004 | 11:11 PM
vtec92lude's Avatar
Default Re: H22A and H23 wiring harness difference? (bwintegra93)
https://honda-tech.com/zerothread?id=1004852
this link will tell all.
Good Luck
Old Oct 20, 2004 | 11:41 PM
SKDRCR's Avatar
Default Re: H22A and H23 wiring harness difference? (vtec92lude)
You can use your old h23 harness.
You'll just have to wire vtec to your new ecu.
You can use the thread above to do that
Old Oct 21, 2004 | 07:10 PM
Default Re: H22A and H23 wiring harness difference? (SKDRCR)
i have read the site you guys posted and it has helped a lot, but the only thing i am stuck on is the "p13" ecu...the ecu i recieved with the h22a has 4 connectors in it, and the diagrams i see on here only show 3....but there is a tag on the v-tec ecu and it has some #'s on it with a p13 in the middle so i take it that is what it is.....so what is the 4th connector? it has 4 wires in it off the harness: green/red stripe ; green/white stripe; green/yellow stripe; blue....help me please.
Old Oct 21, 2004 | 08:21 PM
SKDRCR's Avatar
Can you show us a pic of what you are talking about?
Old Oct 21, 2004 | 08:22 PM
Sabbotage's Avatar
i just recently picked up an H22 swap and my P13 ecu only had 3 connectors. Can you post pics of what you are saying?
Old Oct 23, 2004 | 08:31 PM
Default Re: H22A and H23 wiring harness difference? (Sabbotage)
here are some pics:
http://www.we-todd-did-racing....D.jpg
i hope someone can help me out...this is the only thing i have no idea on.
Old Oct 23, 2004 | 09:02 PM
v4lu3s's Avatar
RTFM
looks like an auto p13 to me.
Old Oct 23, 2004 | 09:35 PM
Default Re: (v4lu3s)
it is an auto car, so are the spare wires in that clip vtec?
Old Oct 23, 2004 | 09:39 PM
99bb6's Avatar
Default Re: (bwintegra93)
my stock obd2b wire harness was really chopped up and jumped by the previous owner's ricer wiring, is it easy to find a new/slightly used obd2b wire harness? how much are they ussually?
Old Oct 24, 2004 | 02:14 PM
CHK4TIX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">looks like an auto p13 to me.</TD></TR></TABLE>
You have to be careful there are JDM P13's that are manual that have 4 plugs. the fourth connector is for the traction control feature that was found on some models. So just because it has 4 plugs doesn't not mean that its and auto ecu, but you are correct on this one that it is for an auto.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bwintegra93 &raquo;</TD></TR><TR><TD CLASS="quote">it is an auto car, so are the spare wires in that clip vtec?</TD></TR></TABLE>
As far as the fourth connector, I believe that is for the traction control feature for the JDM cars and has nothing to do with v-tec. I could be wrong but I have never seen a USDM auto ECU to compare it with.
Old Oct 24, 2004 | 03:27 PM
v4lu3s's Avatar
RTFM
the reason i suggested it was an auto ecu is the fact that the sticker ID's it as an atuo ecu, thus the AT on it.
Old Oct 24, 2004 | 06:54 PM
Default Re: (CHK4TIX)
so if it is traction control, would it hurt anything if i just left it unhooked?
Bambinoh
May 5, 2007 11:43 PM
streetlegalh22
Mar 8, 2006 08:11 PM
NobodysHero
Apr 6, 2004 02:43 PM
mstsh80
Jul 1, 2003 12:49 PM
humtake
May 20, 2003 04:46 AM
