leaking manifold = loss in torque? help!
Old Dec 18, 2001 | 04:04 PM
ToneyTigre's Avatar
New User
Default leaking manifold = loss in torque? help!
i need help. here's my story. so i bought these used DC 4-2-1 headers online and was installing it last night. only to find out that the it doesn't bolt on to the cat! i got jipped! it was prolly for a b18 or delsol... anyways the main point was after i bolted the stock manifold back on i notice a loss in power in the lowend pf my power band. and also my engine check light came on. now, keep in mind that i also replaced the spark plugs. i switched to Bosch Platinum +4. im guessing its the manifold thats causing the problems. what does it sound like to you? is it the spark plugs? or the leaking manifold? does leaking manifold cause loss in power??
and if it is leaking, how do i check for it? initially i crawled under the car to listen to hissing sounds but there was none during idle.
Old Dec 18, 2001 | 04:15 PM
Jared's Avatar
Default Re: leaking manifold = loss in torque? help! (ToneyTigre)
MIL is probably on because you forgot to plug something back in (o2) Bosch +4s suck. I'd go back with NGKs. Honda puts them in there for a reason.
Old Dec 18, 2001 | 04:37 PM
Gennady's Avatar
New User
Default Re: leaking manifold = loss in torque? help! (Jared)
Why do Bosch Platinum +4's suck? After I got mine, they helped that annoying 4th gen Accord idle a little.
Old Dec 19, 2001 | 01:09 AM
ToneyTigre's Avatar
New User
how you explain the loss in power? there is noticeable lag.
Old Dec 19, 2001 | 02:50 PM
976's Avatar
976
New User
If the header isn't designed for your engine then the flow is "cut-off" and that decreases performance. Also, you might have not gapped those plugs, or maybe not tight enough.
Old Dec 20, 2001 | 12:36 AM
ToneyTigre's Avatar
New User
Default Re: leaking manifold = loss in torque? help! (B21A)
what do you mean by "gaping" spark plug?
Old Dec 20, 2001 | 12:54 AM
B18C-EJ1
Guest
Posts: n/a
I agree, the +4's are garbage. Go back to NGK plugs.
If you have a leaking manifold, yes, you will loose HP and Torque. It will also kill your gas mileage too.
Old Dec 20, 2001 | 01:20 PM
ToneyTigre's Avatar
New User
Default Re: leaking manifold = loss in torque? help! (B18C-EJ1)
I think i didn't screw the spring loaded bolts all the way where the cat and collector connects. i'll fix it once i get my car from the shop.
im curious, why are bosch +4 crappy?
Stopsign32v
Feb 21, 2015 03:31 PM
civicracingteam
Feb 14, 2005 07:10 PM
sketcherton
Jan 12, 2004 06:20 AM
BLKCRX
Jan 2, 2003 01:32 AM
