need help fast. car wont warm up?
what up guys , i searched and couldnt find the answer. i moved to washington from vegas and now my car just doesnt warm up. its wierd , in idle it will warm up but takes like a good 15 min. but when i start to drive, it will just go cold again. any ideas>?
ps. my cold start is messed up and doesnt work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10secwantabe »</TD></TR><TR><TD CLASS="quote">The thermostat might be stuck open.</TD></TR></TABLE>
Sounds like thats the problem to me!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T b16a1crx »</TD></TR><TR><TD CLASS="quote">yeah but see if my thermostat was stuck open then wouldnt the fan be on all the time?</TD></TR></TABLE>
No. The fan comes on at a certain temperature, not in conjunction with the opening of the thermostat. Do you have the stock radiator?
I'm gonna go out on a limb here and say it's probably the most obvious that is giving you your problems.
FIX teh cold idle, enjoy.
</TD></TR></TABLE>I'm gonna go out on a limb here and say it's probably the most obvious that is giving you your problems.
well thanks guys hope to fix it. well i was hoping i could figure out why i dont have a cold start, ive tryed some stuff but i really dont know what to do. also when i take out the iacv plug,the cars idle doesnt change so i know somethings wrong with that.
i have the same problem... itll warm up fine at idle sitting in my garage but when i drive... right back down to cold.. it wasnt the thermostat bc i replaced it... (that was when i had my dseries stil) and after the swap it still does the same thing (JDM LS Motor) im stumped.. i think it has something to do with my heater core bc my heat doesnt work for **** it always blows cold or luke warm air.... i need heat.. winters a commin
id say check the thermostat
it is located in the hosing that the radiator hose goes to
pretty sure its the lower hose but not 100% sure
-Brian
-Brian
when i got a oil change they did a cooant test. but you guys could be right about that thermostat. the thing is is i thought your thermostat also controls when your fan turns on which it is doing right?
bimrpwr
Jan 10, 2004 01:03 PM
