which muffler will fit??????????
Old Oct 20, 2004 | 06:14 PM
MIDnightblackDA's Avatar
Default which muffler will fit??????????
I have stainless steel JG performance headers, no cat, 3" piping, and a stock exhaust. my qeustion is would any muffler fit this piping or do i have to buy a specific muffler
Old Oct 20, 2004 | 06:22 PM
G1 TEGGY's Avatar
Default Re: which muffler will fit?????????? (MIDnightblackDA)
match the piping diameter at the actual mating part with the diameter on the muffler mating part and you should be fine, the pipes can be stretched out a little to fit if they're slightly off
Old Oct 20, 2004 | 07:43 PM
dFreezy's Avatar
Default Re: which muffler will fit?????????? (G1_TEGGY)
you have your stock muffler running with 3" custom piping? doesn't sound like an efficient set-up. to answer your question though, most aftermarket axlebacks can be swapped out in place of the stock one. i'm assuming there is some wort of bottleneck in your piping to accomodate the stock muffler. however, you should keep in mind that 3" piping is overkill unless you're boosted. 2.25" is ideal for mild and light mods and 2.5" for more serious mods is a good benchmark to follow.
Old Oct 20, 2004 | 07:56 PM
KaBlammyman's Avatar
Do you have a tubo setup? If not, why is your exhaust piping so large?
Old Oct 20, 2004 | 11:14 PM
Default Re: which muffler will fit?????????? (KaBlammyman)
i do have "certain" plans for turbo. already have a turbo timer. it came with the car when i bought it along with the 3" piping with the stock muffler still on it. so is their any paticular muffler i should purchase for this to work or/and what sizes should I B looking 4?
Old Oct 20, 2004 | 11:18 PM
everything is welded. from the headers to the stock exhaust. but of course the headers r bolted to the engine.
Old Oct 20, 2004 | 11:27 PM
yeegsr's Avatar
every muffler comes with a size...so you need to look for 3" inlet muffler and a brank you like...so...
just curious are you running turbo? or high power N/A....3" sound like you gonna lose power if you are running pretyt much stock..
Old Oct 21, 2004 | 07:48 AM
Default Re: which muffler will fit?????????? (yeegsr)
high power N/A 4 the moment. turbo isn't actaully the less expensive process to do to a car NOW-A-DAYZ.
Old Oct 21, 2004 | 01:59 PM
any certain muffler i should b looking at? BRANDS?
Old Oct 21, 2004 | 02:01 PM
sPaRk'iT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIDnightblackDA &raquo;</TD></TR><TR><TD CLASS="quote">high power N/A 4 the moment. turbo isn't actaully the less expensive process to do to a car NOW-A-DAYZ. </TD></TR></TABLE>
How high is high?? 3" is still too big for n/a under 200hp.
Old Oct 21, 2004 | 02:27 PM
jdmotorsports's Avatar
Default Re: which muffler will fit?????????? (sPaRk'iT)
you cant be running 3" piping into a stock muffler. the stock pipes are under 2". that would be a huge reduction.
if your looking for brands then get yourself a summit or jegs catalog. both sell magnaflow and house brands that would work fine. you'de have to find the right size though, and inlet/outlet location.
Old Oct 22, 2004 | 12:22 AM
Default Re: which muffler will fit?????????? (jdmotorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk’iT &raquo;</TD></TR><TR><TD CLASS="quote">
How high is high?? 3" is still too big for n/a under 200hp.</TD></TR></TABLE>
i don't know really but i know it's out of my budget at the moment. i don't have money like sum of u BALLA'S on H-T.
Old Oct 22, 2004 | 12:24 AM
i haven't checked out the piping myself yet but all i know is what the seller "SIVART" told me and what i read on vechile classifieds.
Old Oct 23, 2004 | 01:10 AM
haven't had a problem with it so far. it's just HELLA loud with the stock muffler. with whatever size piping it iz, but hopefully it will work out.
Old Oct 23, 2004 | 09:59 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIDnightblackDA &raquo;</TD></TR><TR><TD CLASS="quote">haven't had a problem with it so far. it's just HELLA loud with the stock muffler. with whatever size piping it iz, but hopefully it will work out.</TD></TR></TABLE>
personally man...i dont know how much power you got right now....but let say ure running at 200 at the wheel...you still only need 2.5"....if you're pushing 250wheel (which is not that easy) then 3" is a must
other while...your car will be running like ****...man..lose lot of power...if you going to do piping 3 you might at well get new muffler with 3" inlet...stock muffler is out of the question for sure....
im running gsr with stock bolts on with 2.5" piping with new header and muffler...at low end..let me tell you running like ****...people though i got SOHC or retarded SOHC....but at high end....yeah baby spank me
Old Oct 23, 2004 | 10:05 PM
.M.'s Avatar
.M.
get da 3.5' - 4' ebay mufflers y0! dey be making ur car go wahh wahhh brr wahhh!
Old Oct 24, 2004 | 01:06 AM
Default Re: which muffler will fit?????????? ({da.H-T=RICER+aka^JH4DC4})
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {da.H-T=RICER+aka^JH4DC4} &raquo;</TD></TR><TR><TD CLASS="quote">get da 3.5' - 4' ebay mufflers y0! dey be making ur car go wahh wahhh brr wahhh!</TD></TR></TABLE>
thanx 4 the sound affexs. lol! but from what i'm hearin' 3" is TOO big let alone 4" piping.
ninjaturtleEG
14
Sep 16, 2009 05:34 PM
Razr2
Feb 27, 2008 06:32 PM
tachyteg
Dec 1, 2004 06:02 PM
92RedVXHatch
11
Sep 21, 2004 07:53 AM
DeLiRiOu5
Apr 23, 2003 11:56 PM
