ecu question??????
Old Oct 20, 2004 | 04:28 PM
eastwickeg's Avatar
Default ecu question??????
ok guys heres the deal i recentlly had replaced my computer with a p72, and im running it on an SI, its all obd2 now im getting what i think might be a rev limiter kicking in at or around 6500. i dont have a knock sensor hooked up but i am runing a vafc so i still do have vtec, would this computer not seeing a knock signal set the rev limiter at such a low rpm, and another thing thats really got me stumped about it this only happens in 4th gear. I need someones input on this
Old Oct 20, 2004 | 04:34 PM
93lsd's Avatar
Default Re: ecu question?????? (eastwickeg)
do you have your vtm wire plugged in meaning the blue wire on the vafc to you vtec pressure signal wire go too the ecu
Old Oct 20, 2004 | 04:45 PM
eastwickeg's Avatar
Default Re: ecu question?????? (93lsd)
yeah all the wires of the vafc r good soldered connections
Old Oct 20, 2004 | 04:46 PM
eastwickeg's Avatar
i meant 2 say that all my stuff is obd1
Old Oct 20, 2004 | 04:52 PM
93lsd's Avatar
but do you have the vtec pressure switch blue with black stripe wire going too the ecu cut and the blue wire going too the ecu
Old Oct 20, 2004 | 04:59 PM
eastwickeg's Avatar
Default Re: (93lsd)
u kno im not sure ill have 2 check that at work 2morrow, would that do what im explaining
NathanielH
Sep 1, 2006 09:33 PM
boosted1993
Mar 21, 2005 08:34 AM
hondaZvic
Aug 6, 2004 11:40 AM
racinskittle
Sep 27, 2003 09:44 PM
bumpin_bass
Jan 10, 2003 02:32 PM
