VTM wire on VAFC
Old Jan 8, 2003 | 07:00 PM
bumpin_bass's Avatar
Default VTM wire on VAFC
Hey I have a JDM 2nd gen B16a with the P30 ECU. Do I need to hook up the blue VTM wire from the VAFC. I don't have it hooked up and everything seems fine. What does the VTM wire read and what does it stand for?
Thanks
Old Jan 8, 2003 | 09:36 PM
Default Re: VTM wire on VAFC (bumpin_bass)
ttt
Old Jan 8, 2003 | 09:58 PM
Shawn C's Avatar
In The Garage
man all i know is i didnt have to hook it up on my 98 gsr. i wondered the same thing forever
Old Jan 8, 2003 | 11:54 PM
Cnote's Avatar
VTM = Vtec pressure switch
the V-AFC doesn't need to read the pressure switch since the Apexi unit sends the signal to the Solenoid.
Old Jan 9, 2003 | 02:43 AM
TEAMGENDAI's Avatar
Default Re: VTM wire on VAFC (Cnote)
I would hook up the vtm wire for sure. i dont know how to post picks but i can e-mail where to hook it up.
Old Jan 9, 2003 | 06:37 AM
Kataku2K3's Avatar
Default vafc vtm wiring
Just run the blue VTM wire off the VAFC harness to pin D6 on the ECU... You'll need to cut the existing line running from the VTEC pressure sensor to the ECU and tap the VAFC's blue VTM wire to the cut side that runs towards the ECU... Hope this helps... Peace
Old Jan 9, 2003 | 12:00 PM
Default Re: VTM wire on VAFC (teamgendai)
What does it hurt if I don't hook up the VTM. Email me if you don't mind on how to correctly hook it up. Ballzgrande@hotmail.com Thanks
Old Jan 9, 2003 | 04:10 PM
Kataku2K3's Avatar
If you don't wire it up you won't be able to activate your VTEC x-over.. That's how the VTEC controller does it, it tells the ECU that the press is up at a certain RPM and the VAFC also controls the output signal... When installing it it's best to solder all your connections.... check out this, it should help... http://www.apexi-usa.com/productdocu...onics_vafc.pdf Page 11 shows a basic wiring diagram and page 16 shows the actual pin (D6) where the wire is that you need to tap your VAFC VTM signal from... It's the top right diagram (H-2a) on page 16... That's pretty much all there is too it... If you need more help lemme know... Peace
Old Jan 9, 2003 | 04:11 PM
b16b hatch's Avatar
Default Re: VTM wire on VAFC (Kataku2K3)
Its wierd that you have to hook it up on some ecus and some you dont. go to the apex website and get the info.
Old Jan 9, 2003 | 08:46 PM
Hmm. I haven't hooked the VTM up yet, but I set my vtec x-over at 5000 and it kicks on at 5000. This is confusing.
Old Jan 10, 2003 | 02:32 PM
Jaker's Avatar
All the VTM connection does is send a signal to the ECU, to say that the Vtec has activated correctly and the oil pressure is flowing in the head. If you are using a JDM ECU, the connection is totally unnecessary, as the JDM ECU does not look for the VTM (Vtec pressure switch).
boosted1993
Mar 21, 2005 08:34 AM
hondaZvic
Aug 6, 2004 11:40 AM
racinskittle
Sep 27, 2003 09:44 PM
Sivik
Jul 8, 2003 09:14 PM
Accord_Munch
Dec 5, 2002 06:36 AM
