Battery relocation question.
Old Oct 20, 2004 | 03:13 PM
Samkuzma's Avatar
Default Battery relocation question.
Hello to everyone, I am brand new to this forum. I have a question about batteries, that I would appreciate anyone's help on. It is a two part question:
1. I have a 2000 Civc (EX sedan with a 5-speed). In the interest of saving weight I am looking at sealed, dry cell batteries. I am looking at two different batteries, and I was hoping you could tell me what the pros and cons of each one are. The first is an Optima (the 51R). It's specs are 500 cold-cranking amps at 0 degrees F; 625 cold-cranking amps at 32 degrees F; Reserve capacity is 70; weight is 26 lbs. The second battery is an Odyssey (PC680MJT). It's specs are 210 cold-cranking amps at 0 degrees F; 270 cold-cranking amps at 32 degrees F; Reserve capacity is 24; weight is 15 lbs. Obviously I would prefer
the lighter weight of the Odyssey. However, I am concerned about the significantly less cranking amps and reserve capacity. To be perfectly
honest I don't know what those numbers mean exactly, but I think I get the idea that the Odyssey is not as powerful. Part of the issue is that my girlfriend drives the car often and I wouldn't want my lightweight battery to leave her stranded because of its lessened capacity.
2. The second part to my question is a little simpler (I think). I am very interested in placing whichever battery I buy in the trunk. However, I was wondering what exactly would be required (in terms of extra-long cables, etc.) in order to place it there. Is there a resource or company that you know of that could meet my needs with the battery relocation components?
It is probably relevant, so the car is in the Northwest (Washington state), and so it definitely has to deal with cold weather during the winter months. If you could help me with any information/advice or even a referral to somone else who could help, I would really appreciate it. Thanks very much for your time.
Old Oct 20, 2004 | 03:51 PM
Hawkze_2.3's Avatar
Default Re: Battery relocation question. (Samkuzma)
Either battery will be fine as long as you don't have a big stereo or anything that draws lots of power. I have a Braille Battery in my Prelude that wieghs 11lbs and I have never had a problem with it...but then again I don't even have a radio...
For a relocation kit, I'd get a cheap one from Summit, JEGS, etc., or if you think you're up to it, make your own with wire, connectors, and a mounting box...
You'll also need some sort of distribution block because the battery positive terminal must be connected to the starter and the fuse box. Also if you have it, the aftermarket ignition and the stereo stuff...
Old Oct 20, 2004 | 04:08 PM
abnaasefmb's Avatar
Default Re: Battery relocation question. (Hawkze_2.3)
u can go low cash and by some cheap jumper cables that are long enough to reach cut the end off and put new bat. connectors on the bat. end and solder the other end to the old bat. cables. you must secure the bat. down in the trunk dont mess around with this.
Samkuzma
Oct 20, 2004 03:40 PM
Tad
23
Aug 14, 2004 03:47 PM
sslude
Mar 31, 2003 07:37 PM
migs
16
Dec 20, 2002 12:00 PM
