weight question..
Old Mar 24, 2003 | 03:49 PM
sslude's Avatar
Default weight question..
how much does a factory prelude battery wegiht? i was thinking about getting the pc625 (second battery) from http://www.odysseybatteries.com/specs.htm beucase it only weighs 13.2 pounds. have any of you used this battery before, how is it, and did you notice any problems/changes, how long did it last? thanks
Old Mar 24, 2003 | 07:51 PM
sslude's Avatar
Default Re: weight question.. (sslude)
anyone?
Old Mar 24, 2003 | 09:15 PM
DsITR's Avatar
not sure on exact weight...but, it is alot more than 13lbs..
I would speculate its anywhere from 30-50 lbs..
D who hasn't picked up a lude battery in a long *** time.
Old Mar 25, 2003 | 07:06 AM
577HondaPrelude's Avatar
Default Re: weight question.. (dsludefosho)
about 40lbs I think
Old Mar 25, 2003 | 03:31 PM
sslude's Avatar
Default Re: weight question.. (57STS)
cool deal, now has anyone used this lightweight battery before?
Old Mar 25, 2003 | 03:44 PM
aklucsarits's Avatar
New User
The stock one is right around 40 lbs. I bought the equivalent of the PC680, but it's not installed yet. I'll let you know how it goes in a few weeks...
Andrew
Old Mar 25, 2003 | 06:38 PM
sslude's Avatar
Default Re: weight question.. (aklucsarits)
Andrew
cool thanks
Old Mar 25, 2003 | 11:25 PM
ALTERED4's Avatar
ive got the 680, bought it last august (i think)... battery is light, and its small size gets a lot of attention... my car gets turned on once a week (track days) and has no radio...
Old Mar 26, 2003 | 03:37 PM
sslude's Avatar
Default Re: weight question.. (ALTERED4)
is it a good battery for everyday use and the radio always on?
Old Mar 26, 2003 | 03:48 PM
Sticky Tires's Avatar
* B A N N E D *
great thread, i myself is in need of a new battery. i looked at the optima's and found out it's heavy. 13lbs for a battery is good but would it be strong enough for a system + aftermarket alarm?
oh yeah what is the dimension for the stock battery?
[Modified by Sticky Tires, 7:50 PM 3/26/2003]
Old Mar 26, 2003 | 03:58 PM
Chinchilla's Avatar
you said this is going to be your seconed battery? are you keeping your primary battery and adding this one or are you replacing your primary? I cant see why you would need two unless your running some crazy amps
Old Mar 26, 2003 | 06:11 PM
sslude's Avatar
Default Re: weight question.. (Chinchilla)
if your'e talking to me, i was thinking of replacing the factory battery with his one
Old Mar 27, 2003 | 03:28 PM
sslude's Avatar
so noone else uses this battery?
Old Mar 27, 2003 | 05:50 PM
steveg99's Avatar
I don't personally have one yet, but plan to replace the stock battery with the pc680. From what I hear, the battery will crank the engine w/o any problems. But you shouldn't use your radio or lights on when the engine isn't running or else it will drain the battery. Also if you have a sound system, I wouldn't recommend it.
[Modified by steveg99, 6:50 PM 3/27/2003]
Old Mar 31, 2003 | 07:37 PM
ejprimo's Avatar
Default Re: weight question.. (steveg99)
this hawker genesis is the same exact battery as the odyssey battery.
http://www.gotbatteries.com/Productp...tNum=0769-2007
"There is a 10% discount code that should be used during checkout called VMAX . This code needs to be entered in the view cart window using the 'Discount' button."
and if you plan on using your stock connections get these cool looking brass terminals.
http://www.gotbatteries.com/Productp...On04=&AddOn05=
crxaddikt
Honda Civic (2006 - 2015)
Apr 8, 2009 06:25 AM
oldschoolflava
Feb 10, 2008 03:01 PM
clemsoncb7
Jan 5, 2005 10:59 AM
Demonlude
Jun 18, 2004 08:34 AM
redciv
Aug 20, 2002 09:37 AM
