how high can i rev? wit bone stock ls motor?
Old Dec 18, 2001 | 01:33 PM
jdmrealm's Avatar
New User
Default how high can i rev? wit bone stock ls motor?
Old Dec 18, 2001 | 01:59 PM
Kataku2K3's Avatar
Default Re: how high can i rev? wit bone stock ls motor? (4g63turbo)
If your motor is stock don't raise it, there's no point no power up there!
Old Dec 18, 2001 | 02:09 PM
Katman's Avatar
Default Re: how high can i rev? wit bone stock ls motor? (JDMspecEG6)
yep.
also, if you're engine is stock, your stock LS ECU should fail safe you from reving to high on your stock engine. If you want to rev higher, invest in some camshafts and an ECU upgrade to raise the powerband. Although, from experience, you don't want to rev an LS motor too too high. Those B18A/B 1.8L engines powerband dies off around 8000rpm (with cam upgrade) anyways...
Old Dec 18, 2001 | 02:56 PM
jdmrealm's Avatar
New User
Default Re: how high can i rev? wit bone stock ls motor? (Katman)
yep.
Powerband aside...how high can you rev the block ?
Also Katman...what do I need to program ecus? and where can i get mugen and spoon programs from?
Old Dec 18, 2001 | 08:16 PM
non-VTEC's Avatar
about 500RPM more safley (kinda).............anything more than that will wear the beaings down pretty quick.....
Old Dec 18, 2001 | 08:21 PM
SiREF8's Avatar
Default Re: how high can i rev? wit bone stock ls motor? (non-VTEC)
About 500rpm?? Well my 91 Teg can redline about 7000rpm, but I wouldn't push it that far, so you can be the judge of how far you want to rev it, you'll be the one driving it so you determine. <U></U> http://www.intercrewautosalon.com
Old Dec 18, 2001 | 08:22 PM
non-VTEC's Avatar
Default Re: how high can i rev? wit bone stock ls motor? (SiREF8)
i mean 500rpm more than the stock limiter............so about 7500rpm MAX......
Old Dec 19, 2001 | 01:52 PM
SuperMan19's Avatar
New User
Ohh OK that sounds more like it. cuz I've redlined a couple of times b4 on my stock LS and there seems to be no problems.. yet.. haha
Old Dec 25, 2001 | 05:06 PM
DA666's Avatar
Default Re: how high can i rev? wit bone stock ls motor? (MyKarsNameIsMichelle)
6800 even with a chip......but then if u have stand alone, id say around 7500 too..but anymore is bad for valves and will cos tapping soon enough.
Old Dec 25, 2001 | 07:32 PM
eglsvtec's Avatar
i have a ls in my coupe and i am using my stock ex ecu for now and i take it to 7500 some times.....now i have a big tapping noise under my hood now...so bacsially keep all ls motors at 7000 or below....trust me i know......
now time for vtec head
Old Dec 30, 2001 | 05:40 PM
JDMek9's Avatar
New User
Default Re: how high can i rev? wit bone stock ls motor? (eglsvtec)
i think that it is okay to rev to atleast 10,500 rmps with your stock motor, youre not going to have to worry about anything unless your decide that you want to rev it past there then you should probably get an intake and maybe a clutch.
phaphon
May 1, 2009 08:25 PM
PrettyLakesBoy
Mar 19, 2005 02:04 PM
Rod.
Oct 10, 2003 03:11 PM
abs0lutexer0
Aug 4, 2003 10:18 AM
Project_SOHC_EX
Aug 20, 2002 08:52 PM
