Overheating problem
Old Oct 20, 2004 | 08:40 AM
kg4h2l0's Avatar
Default Overheating problem
I have a 94 civic DX it keeps over heating the water pump was replaced and i just replaced the thermostat but its still over heating i need some help before i go crazy and crash the car
Old Oct 20, 2004 | 08:41 AM
g2crx's Avatar
Default Re: Overheating problem (kg4h2l0)
it might be the head gasket.
Old Oct 20, 2004 | 08:43 AM
kg4h2l0's Avatar
Default Re: Overheating problem (g2crx)
u think so well that sucks cause the car was $500 and its gunna cost mad for that
Old Oct 20, 2004 | 08:47 AM
kg4h2l0's Avatar
also the temperature gauge in the car it will go from being cold to real hot then back down to normal again and just keep doing that
Old Oct 20, 2004 | 09:11 AM
LonelyDriver02's Avatar
look at your oil or your coolant, i cant remember which, but i think if the oil looks like a chocolate milk color, then your head gasket is blown and that can cause overheating. You can also do a compression check. Make sure your cooling fan is working. One time I had a FAL fan that broke on me and it would overheat while i was stopped, didn't take long to figure out it was the fan.
Old Oct 20, 2004 | 09:20 AM
g2crx's Avatar
if it'sdoing that it sounds like you got an air bubble in the coolant hoses bleed it see if it helps.
Old Oct 23, 2004 | 12:30 PM
==Catfish=='s Avatar
i got the same problem, you need to bleed the cooling system.
pro306
18
Jul 4, 2013 05:35 AM
gqstatus05
Mar 2, 2012 08:10 AM
jmacc8
Honda Civic (2001 - 2005)
Aug 20, 2010 11:52 AM
kicksremix2o6
Oct 12, 2007 03:31 PM
tianporn
Jun 18, 2005 07:22 PM
