a/f meter q
Old Oct 20, 2004 | 06:08 AM
AWDxBOOST's Avatar
Default a/f meter q
alright, well i hooked it up to my integra dash, and i used the cruise control button harness to draw power
it worked fine, but if i turn my lights on, it drops to what id call a different octave, if that makes any sense
blinkers make it flash back and forth, and the dimmer makes it read at different levels
wish i know wtf was goin on...anyone know why it would do this? i hate wiring
Old Oct 20, 2004 | 07:25 AM
Full Race EG's Avatar
Default Re: a/f meter q (itr_eg)
maybe there is a drop in voltage in the spot you tapped it to. if i were you i would run it directly to the underf dash fuse box. you should be able to use a female connector to plug it into the spot that has 12volts when you turn the key.
Old Oct 20, 2004 | 08:26 AM
PlastikOwl
Guest
Posts: n/a
when you turn on the lights...it dims all of the dash lights...you might have hooked it up to the cruice control light...which would do that. Run it to another circuit.
Old Oct 20, 2004 | 02:56 PM
AWDxBOOST's Avatar
Default Re: a/f meter q (PlastikOwl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlastikOwl &raquo;</TD></TR><TR><TD CLASS="quote">when you turn on the lights...it dims all of the dash lights...you might have hooked it up to the cruice control light...which would do that. Run it to another circuit.</TD></TR></TABLE>
yea thats tru...but i just checked with the old school voltmeter, and its just droppin with different functions
plus the cruise light comes on with the lights, so thats kinda backwords
Old Oct 20, 2004 | 09:13 PM
kuja's Avatar
i hooked all my gauges up off of the power sources right above your fuses. Just put a female connector on it and slid it onto the pin that had power w/ parking lights and headlights on.
fdser
Feb 11, 2010 10:30 AM
Rat_Bear
Nov 11, 2008 12:22 AM
futurefastguy
Sep 8, 2006 06:31 AM
DeeJayStkyRice
Mar 2, 2004 09:01 PM
JLange
Feb 7, 2004 08:06 AM
