Won't flash start anymore..
Old Oct 20, 2004 | 05:22 AM
Quade's Avatar
Default Won't flash start anymore..
I have to hold the key for 2 secs in order for my H22 lude to start on the first try. If I try to start it normal on the first attempt it won't start but it would always flash start on the second attempt. This happens hot/warm/cold. Any ideas?
2 secs is a long time to hold the key. Makes my car seem older than it is.
Old Oct 20, 2004 | 10:23 AM
Odessa's Avatar
Default Re: Won't flash start anymore.. (Quade)
Could be your starter.
Old Oct 20, 2004 | 10:50 AM
98TypeSH's Avatar
Default Re: Won't flash start anymore.. (Odessa)
turn the key, wait for the fuel pump hum to stop, start the car. It should fire up first try, if not its something else.
Old Oct 20, 2004 | 12:25 PM
Quade's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odessa &raquo;</TD></TR><TR><TD CLASS="quote">Could be your starter.</TD></TR></TABLE>
How come? Is swings ok. If so why start on the second attempt?
Old Oct 20, 2004 | 12:28 PM
Quade's Avatar
Default Re: Won't flash start anymore.. (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">turn the key, wait for the fuel pump hum to stop, start the car. It should fire up first try, if not its something else.</TD></TR></TABLE>
I tried that several times. I also have a fuel pressure gauge and it pressurises the system as usual (before I had the problem) on ignition. Any other ideas?
Old Oct 20, 2004 | 12:31 PM
RHD_BB4T's Avatar
Doubt that it would be related to your starter, espescially if it actually turns the motor over everytime you turn the key...
...my guess would either be with 98TypeSH - let the fuel pump prime the system, or it could be that you need to replace the distributor cap/rotor, plugs, plug wires. When's the last time you've had these replaced (or had a tune up?)
Of course, 2 seconds really isn't THAT detrimental...
Old Oct 20, 2004 | 02:02 PM
Odessa's Avatar
Default Re: Won't flash start anymore.. (RHD_BB4T)
It could be the fuel pump, especially if he is low on gas. But if it's not that, then it could be the starter. I had similiar problem on my old civic. Replaced the starter and it started like new!
Old Oct 21, 2004 | 04:37 AM
Quade's Avatar
I have replaced the rotor already - never the cap. The starter is the original.
Old Oct 21, 2004 | 07:48 AM
bb6h22's Avatar
same problem here, i have new plug wires and new plugs. but im kinda low on gas, but the gas light isnt on yet, that might the problem
Old Oct 21, 2004 | 07:55 AM
devi1man's Avatar
Let it turn over for two seconds before it starts. It allows the oil pump to pressurize the engine before it's running.
Toyotas are built that way. Honda may have designed the ECU to do the same thing on initial start
mister.wong
Sep 13, 2008 04:45 PM
sooo_slow
Aug 25, 2004 03:02 PM
AllmotorJunkie
Jul 22, 2004 11:44 AM
shakenbake2001
29
Sep 25, 2003 07:32 AM
