GSR Timing Covers misc. Engine Parts Needed!!!
Im looking for All the Gsr timing covers Top with the bolts, seals etc.
Intake Nuts, Throttle Body nuts and Studs
2 Head Cover Studs,
Cylinder Head Dowel Pins#1, Oil Control Orfice/O Ring
Cam Shaft Oil Seals
Modified by TurboTeG4 at 9:24 AM 10/27/2004
2 Head Cover Studs,
Cam Shaft Oil Seals
I've got:
1.) Cam Gear Bolts, Keys [1pr]
2.) OBD-1 GS-R Lower Timing Belt Cover [only 1 fastener that I can give you that you can use for either the lower timing belt cover or rear upper timing belt cover]
3.) 2 Head Cover Studs [I have the inner ones, but I still need them until I get the engine back to do some testing]
4.) All Head Cover Nuts [All but 1]
4.) Cylinder Head Dowel Pins [I've only got 1 for you]
5.) Exhaust Nuts [9]
I'll post a few pics for you of the quantity and type since there are a few ambiguous things on the list.
If you want all that stuff, it'll be $25 shipped.
Modified by IN VTEC at 10:33 AM 10/20/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 »</TD></TR><TR><TD CLASS="quote">Still looking for upper gsr timing covers and timing cover bolts</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 »</TD></TR><TR><TD CLASS="quote">Im looking for All the Gsr timing covers Top with the bolts, seals etc.
2 Head Cover Studs,
Cam Shaft Oil Seals
Modified by TurboTeG4 at 9:24 AM 10/27/2004</TD></TR></TABLE>
2 Head Cover Studs,
Cam Shaft Oil Seals
