starting engine
Old Oct 19, 2004 | 09:03 PM
esca's Avatar
Default starting engine
what is considered a "long start up" when starting the engine...
im scared that i might have bad compression.. because in the mornings (when its pretty cold) it takes like 2 seconds to start up... but when its warm it starts up hella fast..
is that normal? or is something wrong..
Old Oct 19, 2004 | 11:38 PM
vtec92lude's Avatar
Default Re: starting engine (esca)
IMO 2 seconds is nothing to worry about. But if you are really concerned go pick up a cheap compression tester and check.
Good Luck
Old Oct 19, 2004 | 11:39 PM
esca's Avatar
Default Re: starting engine (vtec92lude)
cooll.. hahah.. thanks
waiting day sfor someone to respond
Old Oct 19, 2004 | 11:48 PM
SKDRCR's Avatar
I usually turn the key forward to the acc position, wait
for the guages to turn off and then crank it.
This gives the fuel pump a chance to prime.
Then start it.
Try that and see if it starts up any faster
Old Oct 19, 2004 | 11:50 PM
BrokeLude's Avatar
ummm have you ever had a car before dude? A motor is always gonna start better when it's warm. Waiting a couple seconds to start is no big deal, nothing is wrong.
Old Oct 20, 2004 | 01:23 AM
safe driver's Avatar
Default Re: starting engine (BrokeLude)
the battery will always put out less current when it's cold out. get a high cranking amp battery if you're really that concerned about the cold start cranking time.
Old Oct 20, 2004 | 01:45 PM
esca's Avatar
sounds good.. haha my bad.. its my first car.. i just try my best to keep it in tip top condition..
Old Oct 20, 2004 | 05:01 PM
MackDad's Avatar
Do you park on a hill or drive around between E or a 1/4 tank? I have noticed this with my Accord...I park on like a 5 degree grade, and have noticed this affects cold starting...Also, low fuel will cause this as well...Like SKDRCR said, turn it to ACC and let the fuel pump prime...
liquidzorch
Sep 8, 2013 08:25 AM
osbunjosh
12
Mar 3, 2013 12:20 PM
Narao
14
Oct 7, 2011 07:25 AM
makinoracer
Jul 19, 2005 06:07 PM
jasongallagher
May 27, 2002 01:36 PM
