my R feels sluggish lately and using more gas , help
Old Oct 19, 2004 | 06:50 PM
Cyber ITR's Avatar
Default my R feels sluggish lately and using more gas , help
i have no idea, its been doing this since i took it to the drags , i have not check the compression yet
but the car definetely using more gas than before , is it because i just installed a custom 2.5" system ??? altho i have the exhaust since like 2 months ago
and also it feels lazy when take off
ive changed the spark plugs with Denso Iridium , same heat range as the replacement , according to the Denso catalog anyway ...
ill do the compression check hopefully this weekend, what sort of #'s should be expecting from a 96 JDM R engine ?? its done 130k km
thanks for reading this
Old Oct 19, 2004 | 06:52 PM
Opie's Avatar
Bad gas? New fuel filter?
Old Oct 19, 2004 | 07:01 PM
Cyber ITR's Avatar
Default Re: (opie)
u think so opie ??
the car has done 130,000 km ~ 52,000mile
and im sure it still has the stock fuel fiter
Old Oct 19, 2004 | 07:17 PM
Opie's Avatar
Couldn't hurt, it's cheap enough.
How long has the problem been going on? Any mis-shifts or similar incidents? Do j00 have oil for the v-tack!?
Old Oct 19, 2004 | 08:59 PM
Bbasso's Avatar
Default Re: (Day Walker)
Air Filter, does it need to be cleaned or be replaced?
Old Oct 19, 2004 | 11:26 PM
Cyber ITR's Avatar
Default Re: (opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie &raquo;</TD></TR><TR><TD CLASS="quote">Couldn't hurt, it's cheap enough.
How long has the problem been going on? Any mis-shifts or similar incidents? Do j00 have oil for the v-tack!?</TD></TR></TABLE>
no i have never mis-shifts , altho ONCE i tried to do flat shifting from 3rd to 4rd @ the drags , it went it smoothly , u think that would cause the problem ??? i still have the rev limiter
the problem is been there since i took it to the drags ....
and air filter, uhmm all i can say its pitch black , LOL still on stock filter
Old Oct 20, 2004 | 05:59 AM
Stinkycheezmonky's Avatar
Suspetise...
Get a new filter, see if that helps at all. The powershifting wouldn't affect the motor I think, just the tranny.
Old Oct 20, 2004 | 06:05 AM
Safir's Avatar
replace teh air and fuel filters, change oil, and maybe give it a bottle fo fuel injector cleaner - 50,000 miles is a long tiem to go on filters, no matter what honda says.
Old Oct 20, 2004 | 08:46 AM
hybrider's Avatar
Default Re: (Safir)
the air and fuel filters are 'supposed' to be changed every 30k
Old Oct 20, 2004 | 09:07 AM
integrasi's Avatar
Default Re: (hybrider)
did you also installed 2.5" header? if so, i'm thinking your a/f ratio is off. might wanna double check your a/f ratio. since bigger piping tends to Reads more exhaust flow. Also you might want to consider doing your valve adjustment again. As you stated, you went to drag race.
Flowing more fuel into engine has nothing to do with dirty fuel filter.
Old Oct 20, 2004 | 09:09 AM
MattD@Stoptech's Avatar
Default Re: (integrasi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrasi &raquo;</TD></TR><TR><TD CLASS="quote">did you also installed 2.5" header? if so, i'm thinking your a/f ratio is off. might wanna double check your a/f ratio. since bigger piping tends to Reads more exhaust flow. Also you might want to consider doing your valve adjustment again. As you stated, you went to drag race.
SHUT UP!!!!!!!!
Old Oct 20, 2004 | 09:10 AM
RobbieG35's Avatar
12 Years Strong
He installed exhaust, not a header
Change the air filter and fuel filter, you will be surprised what a difference it can make
Old Oct 20, 2004 | 03:33 PM
Cyber ITR's Avatar
Default Re: (HybridHatch88)
alright i will change the fuel filter and air filter
and regarding the 2.5" header , my motor is a stock 96 jdm R , comes with the stock 4-2-1 header with 2.5" collector already
thanks for the help guys
Old Oct 20, 2004 | 05:06 PM
Utilitarian's Avatar
Default Re: (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">
SHUT UP!!!!!!!!</TD></TR></TABLE>
He doesn't learn. LOL!
Old Oct 20, 2004 | 05:14 PM
B2FiNiTY's Avatar
Default Re: (Utilitarian)
I'm thinking it could possibly be the 02 sensor or a clogged cat? Also check timing.
Old Oct 20, 2004 | 05:42 PM
totsie7944's Avatar
Default Re: my R feels sluggish lately and using more gas , help (Day Walker)
might need a valve adjustment..... just an idea. Also might need to adjust the fuel pressure....
Old Oct 20, 2004 | 06:45 PM
m R g S r's Avatar
Yea, this would cause the car to lean out, using less fuel, not more!
Old Oct 21, 2004 | 03:34 AM
Cyber ITR's Avatar
Default Re: (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking it could possibly be the 02 sensor or a clogged cat? Also check timing. </TD></TR></TABLE>
i took the cat out , just running 2 resonators
u reckon my o2 sensor stuffed up ???
will check the timing also, whats stock timing at ?
thanks
Old Oct 21, 2004 | 04:01 AM
Do have any codes displayed?
Old Oct 21, 2004 | 04:59 AM
Cyber ITR's Avatar
Default Re: my R feels sluggish lately and using more gas , help (El Pollo Diablo)
i never actually check , OMG
Old Oct 21, 2004 | 08:05 AM
Black R's Avatar
25 Year Member
no CEL at all?
Old Oct 21, 2004 | 08:51 AM
Safir's Avatar
Default Re: (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
Yea, this would cause the car to lean out, using less fuel, not more!</TD></TR></TABLE>
more often than not a dirty fuel filter makes the car run stupid rich. I can't explain it, but it happens. I wouldn't believe it if i hadnt seen it multiple times myself.
I used to have a few articles on the subjet, but the server is gone now.
Old Oct 21, 2004 | 08:57 AM
B2FiNiTY's Avatar
Default Re: (Safir)
Stock timing is 16 +/- 2
Old Oct 22, 2004 | 02:51 AM
Cyber ITR's Avatar
Default Re: my R feels sluggish lately and using more gas , help (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">no CEL at all? </TD></TR></TABLE>
checked today , no CEL at all
looks like im just gonna have to change the fuel filter , air filter , and basic tune ups , maybe check the timing also
thanks guys
crxisok
Jul 5, 2006 07:10 PM
xfrankx
Jan 27, 2005 09:12 AM
antivic
10
Dec 21, 2004 10:56 AM
92greensr
Jan 17, 2004 09:53 AM
pub
Jan 24, 2002 10:13 AM
