CTR pistons .25 O/S
Old Oct 19, 2004 | 11:41 AM
SPOONfdEK's Avatar
Default CTR pistons .25 O/S
Can someone running these pistons explain the process in order to put these pistons in my B18C. my B18C is stock,
do they make the CTR pistons the same size as the ITR ones ?or do you need to hone out the cylinders ? TIA
Old Oct 19, 2004 | 11:46 AM
Dave_B's Avatar
I researched this one just the other day. I came up with 78 posts. Also you can purchase the STD size pistons but most recommend the O/S
Old Oct 19, 2004 | 12:30 PM
JeffS's Avatar
Default Re: CTR pistons .25 O/S (SPOONfdEK)
Yes, they make STD size pistons. Whether you will need to overbore depends on the shape of your cylinder walls.
Old Oct 19, 2004 | 01:04 PM
SPOONfdEK's Avatar
Default Re: CTR pistons .25 O/S (JeffS)
my cylinder walls are brand new . they are in perfect conditions. what size CTR piston would i need to buy for the ITR. thanks again
Old Oct 19, 2004 | 01:09 PM
MattD@Stoptech's Avatar
Standard size.
Old Oct 19, 2004 | 01:12 PM
SPOONfdEK's Avatar
Default Re: CTR pistons .25 O/S (El Pollo Diablo)
standard size for the itr or standard size for a ctr ? sorry for the dumb ?
Old Oct 19, 2004 | 01:13 PM
both
Old Oct 19, 2004 | 01:49 PM
DC2fanboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">both</TD></TR></TABLE>
(i.e. they are the same size )
Old Oct 19, 2004 | 01:55 PM
Chiller's Avatar
can just put these in but could the car run fine with no tuning?
Old Oct 19, 2004 | 02:27 PM
SPOONfdEK's Avatar
Default Re: (Chiller)
ok so the standard CTR and ITR use the same size. DO any of you guys have the exact size ?
Old Oct 19, 2004 | 07:09 PM
SPOONfdEK's Avatar
Default Re: (SPOONfdEK)
ttt
Old Oct 19, 2004 | 07:12 PM
uNF$@#!'s Avatar
94.5 mm bore
go....go bore it all away....
Old Oct 19, 2004 | 07:20 PM
uNF$@#!'s Avatar
Default Re: (BlueR)
youre too nice marc
Old Oct 19, 2004 | 07:28 PM
BlueR's Avatar
Default Re: (w@@t w@@t)
see title
Old Oct 19, 2004 | 07:49 PM
SPOONfdEK's Avatar
Default Re: (BlueR)
OMFG what ?
Old Oct 19, 2004 | 08:10 PM
BlueR's Avatar
deleted my post, find it yourself
Old Oct 19, 2004 | 08:20 PM
thad
Guest
Posts: n/a
this info is very easy to find,what you need to search for is B16b bore, then check B18C bore, and you'll find enough info to answer your question,
just search ctr piston and you come up with a very broad range of topics that wil bring alot to light and make your project alot easier.
Old Oct 19, 2004 | 09:13 PM
RPRacing's Avatar
SEARCH - not even 2 days ago did this same topic get asked in here. you are new. your question has beeen asked before. your idea isnt original therefore someone else has most likely already asked/answered the info you are searching
https://honda-tech.com/zerothread?id=1026985
Old Oct 19, 2004 | 09:29 PM
irev210's Avatar
Default Re: (sucka306)
easy enough, both will work
but check your clearences and save your overbore for later
Old Oct 20, 2004 | 05:11 AM
EEK's Avatar
EEK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOONfdEK &raquo;</TD></TR><TR><TD CLASS="quote">Can someone running these pistons explain the process in order to put these pistons in my B18C. my B18C is stock,
do they make the CTR pistons the same size as the ITR ones ?or do you need to hone out the cylinders ? TIA </TD></TR></TABLE>
all you need to do is hone the block to install the pistons
Old Oct 20, 2004 | 03:41 PM
SPOONfdEK's Avatar
Default Re: CTR pistons .25 O/S (EEK)
thanks EEK and irev210, im not going to get into it with you bluer, it takes you longer to be an ******* than it does to help me out, if you dont want to answer something then just go on your way , but no here you come to be the H-T hero and tell me to search, if i asked its because i dont know, and i dont know what to search for exactly .
Old Oct 20, 2004 | 03:43 PM
SPOONfdEK's Avatar
thank you, very helpful link you sent me .
Old Oct 20, 2004 | 04:59 PM
slow_dx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiller &raquo;</TD></TR><TR><TD CLASS="quote">can just put these in but could the car run fine with no tuning?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=717928
That's a lot of compression for no 'fine tuning'.
Old Oct 20, 2004 | 05:56 PM
Type-R Yo!'s Avatar
New User
All B16, B16B and B18s have the same size of bore (81 mm).
cthan3o3
Aug 22, 2005 10:54 PM
LSvtechatch97
Apr 17, 2005 12:47 AM
10000rpm
Aug 11, 2004 07:22 AM
juicedricer
Apr 11, 2003 01:34 PM
Toda Party
Jul 13, 2002 10:28 AM
