Integra smokes in high rpms??
Old Oct 19, 2004 | 08:52 AM
5thGenKing's Avatar
Default Integra smokes in high rpms??
My 91 Integra B18a smokes in high rpms but it doesnt an other time i did a compression test on it and got 160 all the way across.It Doesnt lose any power and it doesnt burn a whole lot of oil it goes through about a extra quart of oil per change.Whats the avrege compression per cylinder?what could be wrong?any info would be great
Old Oct 19, 2004 | 09:23 AM
5thGenKing's Avatar
Default Re: Integra smokes in high rpms?? (5thGenKing)
Bump
Old Oct 19, 2004 | 09:25 AM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
your piston rings are probally worn and you're getting a little blow by. your compression sounds a little low. I think it should be around 210, but I'm not entirely sure about that number. Somewhere between 190 and 210 I think. Wait and get a few more opinions though.
Old Oct 19, 2004 | 09:44 AM
5thGenKing's Avatar
Default Re: Integra smokes in high rpms?? (marsbike)
Thanks Man, Can anyone else give me a little Bit more info
Old Oct 19, 2004 | 09:56 AM
PrettyLude's Avatar
valve stem seals are worn
Old Oct 19, 2004 | 01:34 PM
5thGenKing's Avatar
Default Re: (PrettyLude)
Do u guys believe it one or the other or both?
Old Oct 19, 2004 | 03:57 PM
5thGenKing's Avatar
Default Re: (5thGenKing)
Bump Bump Bump
Old Oct 19, 2004 | 04:10 PM
oneforce's Avatar
man, i think ur piston rings are in need of replacement...i did a compression test on my b18a and the readings were 210-215 ....i thinks it's time to rebuild....
Old Oct 19, 2004 | 09:19 PM
r0nr0n's Avatar
Default Re: (oneforce)
I SAY NEW RINGS ALSO
IM BURNING ABOUT 4-5 QTS A WEEK.WHEN I DOGG IT BLUE SMOKES COVERS ANY CAR BEHIND ME (ITS BEAT)
Old Oct 19, 2004 | 09:53 PM
yeegsr's Avatar
what compresion numbers the consider moderate....for gsr then...160 does sound low...200 is average?
Old Oct 20, 2004 | 10:34 AM
PrettyLude's Avatar
i think it can be both, but leaning more towards the valve stem seals
does it smoke at idle at all?
if not i think its the valve stem seals
Old Oct 20, 2004 | 10:52 AM
92CIVICCX's Avatar
Join the club... my teg does the same.. ive come to the conclusion its valve seals. i go through about a quart every change also... it come with havinghigh mile on the motor... ive been thinking about buying and rebuiling a head and puttin it on next summer. but its my daily driver/autocrosser...so as long as it runs good and strong im not gonna worry to much
Tysnet
25
Sep 26, 2011 06:55 PM
Destructive-
Aug 21, 2009 08:24 PM
h2b_sedan
Apr 3, 2008 07:16 AM
Soled Out
Sep 9, 2003 05:08 AM
