intermittent compression loss?!?!
Old Mar 14, 2008 | 04:34 AM
h2b_sedan's Avatar
Default intermittent compression loss?!?!
so i got a b16 turbo setup from a buddy a couple weeks back that had been sitting for several months. it ran perfect when he pulled it out. then i got it in my car and it has compression sometimes and then sometimes its got nothing. could it be the rings seizing up from sitting? valve seals? lemme know if you've ever heard of or experienced this problem. thanks
Old Mar 14, 2008 | 07:17 AM
h2b_sedan's Avatar
Default Re: intermittent compression loss?!?! (h2b_sedan)
bump
Old Mar 14, 2008 | 08:11 AM
hellakapps's Avatar
i had the same prob with an ls but i never got comp out of it still waiting to tear it apart, i'm guessing it's the rings though when they sit you can build moisture in which builds rust which can sezie the rings and tear them up from all the rust on the walls
Old Mar 14, 2008 | 09:46 AM
h2b_sedan's Avatar
Default Re: intermittent compression loss?!?! (hellakapps)
yeah. i'm gonna pour a couple drops of oil in through the spark plug holes and see if that frees them up a bit. i really can't see it as a hard failure because it had compression and then didnt. but we'll see. i'll post later on after i try it.
Old Mar 17, 2008 | 01:52 AM
h2b_sedan's Avatar
monday morning bump
Old Mar 17, 2008 | 09:24 AM
B20luda's Avatar
haha...
Intermintant compression loss is more likely due to valve adjustment issues or carbon holding the valves open, rings rusting from moisture is just retarded...
Old Mar 17, 2008 | 10:13 AM
hybrid_KJ's Avatar
Default Re: intermittent compression loss?!?! (B20luda)
Too tight of a valve adjustment gets my vote. Loose enough so that there is compression cold but when it gets really warm valve(s) can stay open.
Old Mar 18, 2008 | 01:29 AM
h2b_sedan's Avatar
Default Re: intermittent compression loss?!?! (hybrid_KJ)
thanks guys i'll check the valve clearances today and update later on tonight hopefully.
Old Mar 25, 2008 | 07:55 AM
h2b_sedan's Avatar
welp got pissed off and went ahead and got it tuned...
Old Mar 25, 2008 | 08:32 AM
93CX's Avatar
Pretty good numbers considering
Old Mar 26, 2008 | 02:26 AM
civicgeek133's Avatar
Default Re: intermittent compression loss?!?! (93CX)
very good for a stock sleeve b16 at only 15 psi did u ever get the compression thing fixed corey
Old Mar 26, 2008 | 02:54 AM
mrx's Avatar
mrx
Default Re: intermittent compression loss?!?! (civicgeek133)
can you tell us some details of your setup?
would be also interesting if you have found the compression issue
btw. Nice numbers
Old Mar 26, 2008 | 10:05 AM
h2b_sedan's Avatar
Default Re: intermittent compression loss?!?! (mrx)
havent had a problem with the compression since the tune... :/ still kinda worried but we'll see. its a stock sleeve b16, eagle rods, cp 9 to 1 pistons, gsr cams, custon mani and downpipe, 60-1 turbo, edelbrock intake mani, 750's, 3 bar.
Old Mar 26, 2008 | 10:13 AM
steven_highet's Avatar
What A/R is on the turbo?
Great torque curve!!
h2b_sedan's Avatar
Default Re: intermittent compression loss?!?! (steven_highet)
.70 i think. lol that torque curve is so sick!!!!
Old Apr 3, 2008 | 07:16 AM
h2b_sedan's Avatar
bump someone on here has had to have had this problem before.
nemesis25
Jan 12, 2015 04:17 PM
dominate9
Feb 27, 2007 12:27 PM
Sketch_hs
Feb 17, 2006 05:44 AM
zigs
Aug 31, 2005 02:12 PM
311
Dec 14, 2002 12:18 PM
