will my pt-sc61 get me to 500whp?
Old Oct 18, 2004 | 06:57 PM
vaporboy12's Avatar
Default will my pt-sc61 get me to 500whp?
if so where will it start to go out on me?
Old Oct 18, 2004 | 07:03 PM
m R g S r's Avatar
Default Re: will my pt-sc61 get me to 500whp? (vaporboy12)
Should, what are the specs?
Old Oct 18, 2004 | 07:57 PM
vaporboy12's Avatar
Default Re: will my pt-sc61 get me to 500whp? (m R g S r)
.60a/r on compressor side and .63 on exhuast
Old Oct 18, 2004 | 08:00 PM
DRIVENRacing's Avatar
efficient around 12psi plus.... very good turbo for good powerband mid to high range.. 500 very possible with good tune..
Old Oct 18, 2004 | 08:21 PM
vaporboy12's Avatar
Default Re: will my pt-sc61 get me to 500whp? (TurboHybridEG6)
ok thanks for the help
Old Oct 18, 2004 | 08:43 PM
b16sedan's Avatar
Hybrid901 made I think it was 540 WHP with an SC61. Lots of potential.
Old Oct 18, 2004 | 08:48 PM
vaporboy12's Avatar
Default Re: will my pt-sc61 get me to 500whp? (b16coupe)
normally witha 2.0l 9:1 compression ls bottom end and b16 head what boost pressure will i see 500 or so. i know psi i irrelevant to horespower but what have other people made it at
Old Oct 19, 2004 | 12:19 PM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 &raquo;</TD></TR><TR><TD CLASS="quote">normally witha 2.0l 9:1 compression ls bottom end and b16 head what boost pressure will i see 500 or so. i know psi i irrelevant to horespower but what have other people made it at</TD></TR></TABLE>
I'd say anywhere from 20-26 psi.
Old Oct 19, 2004 | 12:49 PM
93LSivic's Avatar
I made 406whp and 291 tq with my SC61 at 12 psi. This was at 7500 rpms, couldnt rev higher cause I had ignition problems.
This is a built GSR 1.9L, 9:1 compression, stock head portwise.
Old Oct 19, 2004 | 05:28 PM
vaporboy12's Avatar
Default Re: will my pt-sc61 get me to 500whp? (93LSivic)
thanks for the help guys
Old Oct 21, 2004 | 10:00 PM
sc61
Old Oct 22, 2004 | 07:09 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">I made 406whp and 291 tq with my SC61 at 12 psi. This was at 7500 rpms, couldnt rev higher cause I had ignition problems.
This is a built GSR 1.9L, 9:1 compression, stock head portwise. </TD></TR></TABLE>
Pump gas? 93octane?
Old Oct 22, 2004 | 07:45 AM
93LSivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
Pump gas? 93octane?</TD></TR></TABLE>
Yes, and yes. 23.1 degrees timing in it. IAT's were around 70.
Old Oct 22, 2004 | 07:47 AM
m R g S r's Avatar
Awsome, so it was pretty cool out huh?
Old Oct 22, 2004 | 07:52 AM
93LSivic's Avatar
Yeah, air temp definetly played a role. But hell, Im happy with it. Too bad I retired that setup though. Last night I just finished putting on the new turbo and wastegate.
esurds
25
Apr 15, 2010 05:33 AM
Suprdave
Sep 28, 2005 09:00 AM
NegroEk
Sep 18, 2005 11:55 AM
Mike@CCT
Jun 23, 2005 07:03 PM
CiViC SiR
Oct 3, 2003 04:27 PM
