removing charcoal canister
Old Oct 18, 2004 | 05:32 PM
hOndafienD 04's Avatar
Default removing charcoal canister
is there any lines that i need to plug up after i remove it? im trying to make some extra space in my engine bay and am just about removing anything useless...thanks
Old Oct 19, 2004 | 02:54 AM
Old Oct 19, 2004 | 08:46 AM
LudeyKrus's Avatar
Bump, i'm interested. I remember seeing 3 hoses coming from that canister, IIRC. What needs to be done with these?
Old Oct 19, 2004 | 09:09 AM
killa_lude's Avatar
Default Re: (LudeyKrus)
i just disconnected everything it works fine. Make sure you know what your doing. I wish i could help you more but i did mine about a year ago.
Old Oct 19, 2004 | 09:20 AM
i'll just remove it, if everything runs fine and stuff i'll leave it off..if theres problems i'll put uit back
Old Oct 19, 2004 | 09:42 AM
Hawkze_2.3's Avatar
Default Re: (hOndafienD 04)
It's just a matter of looking at what you're doing. Remove the canister and all the lines connected to it and you'll have 3 holes left open--
--one on the sensor next to the MAP behind the IM (cap this one off)
--one on the TB (cap this one off)
--one on the vent line from the gas tank. I wouldn't cap this one off as it vents the gas tank. What I did was cut the line near the rear wheel so it will vent into fresh air and not into the engine compartment...
Old Oct 19, 2004 | 10:00 AM
LudeyKrus's Avatar
Default Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">It's just a matter of looking at what you're doing. Remove the canister and all the lines connected to it and you'll have 3 holes left open--
--one on the vent line from the gas tank. I wouldn't cap this one off as it vents the gas tank. What I did was cut the line near the rear wheel so it will vent into fresh air and not into the engine compartment...</TD></TR></TABLE>
Good info! Thanks man!
Old Oct 19, 2004 | 12:21 PM
killa_lude's Avatar
exactly what i did.
boostedem123
Apr 13, 2016 05:02 PM
wasabivtec
Jan 27, 2011 07:45 PM
dkrex001
Sep 27, 2006 11:03 AM
TOP END MS
Feb 27, 2006 04:20 PM
clemsoncb7
Jun 7, 2005 03:35 AM
