e brake
Old Oct 18, 2004 | 05:27 PM
crx90rcr's Avatar
Default e brake
well my crxs e-brake goes like almost straight up i think its to loose. how long does it take to fix and how high should it go
Old Oct 18, 2004 | 05:41 PM
crx90rcr's Avatar
Default Re: e brake (crx90rcr)
well i want to fix it now so im wondering
HatchMo's Avatar
this is on a hatch (should be similar NOT exact)
there are two plate things on the center comsole,one infront one in back of the e-brake, lift them up there should be 2 screws in each take them out lift up the console over the ebrake. You should see the cable with 2 nuts the one nearest the driver hold in place then tighten the one towards the pasenger.
This is on a 91 si hatch just did it this week thats why i went so in depth
good luck hope this helped
Old Oct 18, 2004 | 05:44 PM
crx90rcr's Avatar
Default Re: e brake (HatchMo)
yea thanks
Old Oct 18, 2004 | 06:02 PM
eda6's Avatar
e-brake cable should be fully tensioned between 6-10 clicks
Old Oct 18, 2004 | 06:05 PM
b16turbokilla's Avatar
Can be fixed fairly easy and like mentioned before 6-10 clicks
Old Oct 18, 2004 | 07:02 PM
crx90rcr's Avatar
Default Re: e brake (b16turbokilla)
well i just tried working on it but i cant get the counsole out cuz the 2 screws wont loosen i sprayed with wd40 but still it isnt comeing out i need to fix it really bad any tips on how 2 get it
Old Oct 18, 2004 | 07:33 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx90rcr &raquo;</TD></TR><TR><TD CLASS="quote">well i just tried working on it but i cant get the counsole out cuz the 2 screws wont loosen i sprayed with wd40 but still it isnt comeing out i need to fix it really bad any tips on how 2 get it
Just remove the cover under the ashtray and handle your business. The e-brake can be adjusted with out removing the console.
redm3turbo
Jun 23, 2012 02:53 PM
t_mac
Jan 13, 2009 01:13 AM
accordianex
Aug 16, 2008 08:14 AM
D16Z6racing
Nov 4, 2002 05:27 AM
citanest
Feb 27, 2002 01:48 AM
