Sqweaking clutch...
Old Dec 17, 2001 | 08:55 PM
Paisan's Avatar
New User
Default Sqweaking clutch...
I have a Clutchmaster Stage III clutch, and I've had it for awhile now. Whenever I let off the clutch or push the pedal in half way, I get a constant chirping. Is the release bearing going out or is it something else?
Old Dec 18, 2001 | 06:53 AM
WAFFLES's Avatar
Default Re: Sqweaking clutch... (Paisan)
when you push it in half way, do you hold it there and it rattles. Or, does it just squeek when the pedal hits the half way point?
Old Dec 19, 2001 | 10:21 AM
Paisan's Avatar
New User
Default Re: Sqweaking clutch... (WAFFLES)
Sqweaks, actually, more like chirping.
Old Dec 19, 2001 | 10:32 AM
WAFFLES's Avatar
If it rattles while setting at idle, and is quiet when the clutch is pressed...definitley the throwout bearing
Old Dec 19, 2001 | 02:04 PM
shamoo's Avatar
Will you make something up for me please?
Stage III? Is that the clutch disc with the metallic compound? Any metallic/ceramic disc will squeak when you engage it.
My ACT 4 puck goes nuts when I start out in 1st. Like a bunch of dying cats. Heehee.
But if it's not that type of clutch, it's your throwout bearing. Did you have that replaced when you did the clutch?
Old Dec 19, 2001 | 02:41 PM
976's Avatar
976
New User
Default Re: Sqweaking clutch... (shamoo)
My pedal is always pushed in and the released. I never hold down my clutch.
[Modified by B21A, 11:41 PM 12/19/2001]
MiNeSEK
19
May 11, 2013 12:05 AM
WildChild
Nov 18, 2005 07:25 PM
4LugR
May 6, 2005 04:12 PM
slowj
Jan 18, 2004 06:25 AM
