what does SAE corrected mean?
Old Dec 17, 2001 | 08:33 PM
Hacemuy's Avatar
Default what does SAE corrected mean?
I see it on all dyno results, what is it?
Thanks in advance...
Old Dec 17, 2001 | 10:17 PM
Hacemuy's Avatar
Default Re: what does SAE corrected mean? (SOMEguyFROMoregon)
Anybody know??
Old Dec 17, 2001 | 10:22 PM
yellow blur's Avatar
i dont know what exactly the acronym stands for, but it's the correction for altitude factor.
/edit/ just did a little research, and i came up with The Society of Automotive Engineers, i guess it's their specs that the dyno's correct to.
[Modified by yellow blur, 11:25 PM 12/17/2001]
Old Dec 17, 2001 | 10:35 PM
Hacemuy's Avatar
Default Re: what does SAE corrected mean? (yellow blur)
thanks yellow blur, now how do you do this? does anyone have an example?
Old Dec 18, 2001 | 03:43 AM
Piston Honda's Avatar
I don't know how the exact calculations are made but its based on air density, which is based on air pressure, air temperature, and vapor pressure.
Old Dec 18, 2001 | 05:17 AM
davidnyc's Avatar
Default Re: what does SAE corrected mean? (Piston Honda)
try this website, they may have some info:
http://www.howstuffworks.com
(P.S. my favorite website !! Also for computer information=> http://www.whatis.com )
Old Dec 18, 2001 | 05:21 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
if i am not mistaken, SAE stands for Standards in Automotive Excellence or Society of Automotive Engineers. but, i think it is the standards one.
Old Dec 18, 2001 | 06:16 AM
HX_Guy's Avatar
Default Re: what does SAE corrected mean? (rodney)
SAE is a correction factor to set all things equal between dynos.
So, if you dyno your car in Cali or in Coloroado...you would (supposed to) get the same results when they are SAE corrected.
SAE correction sets everything as if it was the perfect conditions. This included altitude, temperature and atmosphere pressure.
For example, here in Phoenix, in the summer the SAE sorrection fasctor is 1.07 while in California its more around .99. So, the car is California is actually putting down more power to the ground then the one in Arizona...but with SAE correction they will be the same.
Arizona= 158.8 HP Actual
170.0 HP SAE
California= 171.7 Actual
170.0 SAE
So when you dyno the car..both cars would show 170 SAE HP...yes in reality the car in California is making 13 more WHP due to different altitude, temp. and pressure.
Old Dec 18, 2001 | 06:39 AM
rtype11's Avatar
Society of Automotive Engineers - they determine everything that has to do with standardization for anything automotive in the USA. they even are responsible for designating and approving new technologies for use in cars and even steel grades for use in cars. you can buy the standard that governs the correction factors involved in dyno testing. SAE HP correction is a method of putting every single dyno on the same basis by correcting all the various atmospheric conditions to a known control - so when you compare a dyno with a GSR in death valley with one in Denver those are the non disadvantaged/advantaged results.
Ryanhooligans
Sep 13, 2006 11:25 AM
EK FLY
Aug 27, 2005 05:49 PM
bluedevil
Mar 24, 2004 08:18 PM
