ok now what is the problem i have no clue
Old Oct 18, 2004 | 11:31 AM
mrnice1058's Avatar
Default ok now what is the problem i have no clue
ok i finally got the check engine light done now the one problem i am having is when i start my engien i am getting a whining from the lower part of my timing belt area could it be my tension on my timing belt could it be the tensioner itself what else could i look for thanks guys
Old Oct 18, 2004 | 11:46 AM
spoonek9's Avatar
Default Re: ok now what is the problem i have no clue (mrnice1058)
I would unhook all your accessory belts, one at a time, and each time you remove a belt start the car and listen for the noise. I had a similar noise, I thought it was my water pump, turned out to be the bearing in the A/C tension pulley.
Old Oct 18, 2004 | 11:58 AM
mrnice1058's Avatar
Default Re: ok now what is the problem i have no clue (spoonek9)
ahhhhhhh thanks i thought about it but i didn't think it would be the problem i will check that tomorrow thanks for you help
SilvrBullet GSR
Oct 13, 2007 01:15 PM
bb608901
Aug 5, 2007 03:52 PM
onesloweg
Mar 28, 2007 02:41 AM
94gsr_vtc
Nov 12, 2004 08:30 AM
salvageland
Oct 27, 2004 09:51 AM
