Electric Gurus: Who *MAJORLY* Knows There Shit? (hacked harness b4 ecu)
Old Oct 18, 2004 | 10:55 AM
1 Cam Wonder's Avatar
Default Electric Gurus: Who *MAJORLY* Knows There ****? (hacked harness b4 ecu)
Needless to say my car was vandalised, and to take my pg7 ecu the just cut the main harness about 2 inches from my ecu.
Went to the junkyard and hacked about 4 inches onfront from another Si Crx in the yard
But to my surprise, some wires are the same ******* colours, the same colors are mostly beside eachother in the clip.
How am I supposed to go about wiring this back together?
Car is a Canadian 88 Si
Thanks for any help
Old Oct 18, 2004 | 10:57 AM
crx_88_si's Avatar
where are you located in Canada?
if in the gta i might be able to help you out one day..
also, email me mike@homemadeturbo.com and i'll send you a pinout in Excel format.
Old Oct 18, 2004 | 11:00 AM
crx_88_si's Avatar
well im done work for the day,.. i'll check back later.
Old Oct 18, 2004 | 11:03 AM
Home Skillet's Avatar
Default Re: Electric Gurus: Who *MAJORLY* Knows There ****? (1 Cam Wonder)
http://tech2.hybridgarage.com/...pr3_a
Old Oct 18, 2004 | 11:06 AM
Default Re: Electric Gurus: Who *MAJORLY* Knows There ****? (Home Skillet)
Old Oct 18, 2004 | 09:59 PM
What does that diagram do for me? My wires werent pulled out of the clips, they were cut, just have to connect them to the harness pictured in the first post
Thanks though
Old Oct 19, 2004 | 03:01 AM
That's just to show you the pinout configuration and match it up to the diagram. Unless the colors don't match up in the car?
Old Oct 19, 2004 | 04:58 AM
ef8 h0!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Cam Wonder &raquo;</TD></TR><TR><TD CLASS="quote">Needless to say my car was vandalised, and to take my pg7 ecu the just cut the main harness about 2 inches from my ecu.
wait, you found a crx in a junk yard? where? it must just be that i live in utah but nothing ef can be found in a junk yard here.
Old Oct 19, 2004 | 08:24 AM
Default Re: Electric Gurus: Who *MAJORLY* Knows There ****? (bernie'sb16crx)
Ya this crx was pretty fresh. Only missing the motor,brakes, seats and carpet
I snagged the cluster, ac unit, gas door, ecu wire harness and some misc bolts I was missing
Still dont understand what I can do with these pinouts
Old Oct 19, 2004 | 08:38 AM
crx_88_si's Avatar
they list the pin#, wire colour and function, that should be all you need to figure this out.
Old Nov 3, 2004 | 02:00 PM
m3dia_lab's Avatar
thats only for vtec, i need the same thing...
we need the list for all the pins
Old Nov 3, 2004 | 10:04 PM
bloopie's Avatar
Default Re: (m3dia_lab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m3dia_lab &raquo;</TD></TR><TR><TD CLASS="quote">thats only for vtec, i need the same thing...
we need the list for all the pins</TD></TR></TABLE>
WTF are you talking about? Every pin is there.. LOOK man... jesus.
Old Nov 3, 2004 | 10:51 PM
drussell4801's Avatar
Default Re: (veReze)
ok.
the pictures he posted are pictures intended to help someone do a vtec wireup
but that don't necessarily mean you can't use it for what you're trying to do.
Old Nov 4, 2004 | 01:26 AM
bloopie's Avatar
Default Re: (drussell4801)
It shows each socket.
And the color of the wire going into each socket.
If you can't figure it out, please pay someone to do it.
Old Nov 4, 2004 | 04:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Home Skillet &raquo;</TD></TR><TR><TD CLASS="quote"> http://tech2.hybridgarage.com/...pr3_a </TD></TR></TABLE>
I quoted myself again just incase people just scroll to the bottom without reading what's in the thread
Old Nov 4, 2004 | 06:52 AM
rioninja's Avatar
From the look of your pic, you shouldnt have to worry about the few with matching colors.
A few of the wires will join together later in the harness, so it doesnt matter which one goes to which. Honda used two pins for the same output for a few things.
To double check it, just check the same-color wires for continuity.
what1118
Dec 15, 2007 07:00 PM
Solscud007
Jan 10, 2006 10:58 AM
dasher
Apr 26, 2004 04:01 PM
filthyCREX
Nov 4, 2003 01:33 AM
