octane rating
Old Oct 18, 2004 | 10:41 AM
motocross 04's Avatar
Default octane rating
which gas station has the best octane rating, or who has the best gas
Old Oct 18, 2004 | 10:43 AM
SOHC4life 96's Avatar
Default Re: octane rating (motocross 04)
IBTL
Each station has its own octane rating. 76 has 87, 89, and 91 Others have 92
Use whatever gas you like.
Old Oct 18, 2004 | 12:22 PM
Default Re: octane rating (DOHC4life)
thanks, i use shell v power
Old Oct 18, 2004 | 12:40 PM
spoonek9's Avatar
Sunoco 93, 94 or 100
Old Oct 18, 2004 | 12:42 PM
=GAME='s Avatar
the question is, does your motor need premium unleaded fuel?
Old Oct 18, 2004 | 12:55 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by motocross 04 &raquo;</TD></TR><TR><TD CLASS="quote">which gas station has the best octane rating, or who has the best gas</TD></TR></TABLE>
Most stations in a given area use the same gasoline, just with a different additive package.
As for octane rating, in a stock engine use whatever the manufacturer specifies. If your engine's manufacturer only requires 87 octane, then it can safely run without detonation on 87 octane, and using a higher octane fuel is just a waste of money. Be grateful that you can actually run the inexpensive fuel. If your engine requires 91 octane, then use 91 to avoid detonation.
All stock or lightly modded D-series engines run fine on 87. DOHC VTEC engines require a minimum of 91.
If you have significantly advanced timing, internal engine modifications that involve high compression, and/or have power adders (including turbo, supercharger or nitrous) then you should use premium fuel as a precaution.
Old Oct 19, 2004 | 06:02 PM
HighVelocity's Avatar
ls engines run perfect on 87 and running a little higher octane can give you better gas millage
JDM KING
16
Jan 17, 2011 04:13 PM
square_1
19
Dec 30, 2007 06:50 PM
DJP
45
Jul 12, 2007 02:20 PM
pandacivic
13
Jul 29, 2004 01:26 PM
helen
Oct 27, 2002 01:19 AM
