Should I sell my Spoon Cams???
Currently I have these cams in my newly built 9:1 CP pistoned, Crower rods B18C4 (B18C1 Equivalent). Vortech Aftercooled Charger (9Psi). I used my old N/A setup and put the Spoons in. Currently they are set on TDC. Started the engine up, idled fine. Now the more I start it up, the worse it gets! Idle is lumpy, misfiring like a bitch to 3K rpm and plugs fouled to ****... (BCPR7ES gapped to .30) Would the cams be the cause for my car to do this?
Before I spend a load on sensors like IAC etc I need FI gurus help!!! (Not alot of FI B motors here in the UK
)Thread
