crankcase breather setup?
I have a fresh ITR H1 motor that has a endyne breather can that spews about at least a qt of oil in the engine bay even when you wrap it with 3 or 4 rags.
The endyne catch can was set-up like this.....
top port-goes to just of the drivers side of oil filter into the block
2nd port down has a t-fitting with hose to valve cover....
Then the bottom drain back port is t'd into the 2nd ports hose going into the block on the passenger side of the oil filter...
The drain back hose into the valve cover hose that is also fitted to the block seems odd?
Any idea's
Paul
Any idea's
Paul
PaulB
Your post is a little confusing but I will give it a try
one of the side ports to the block
second side port to the block
bottom port tee'd into one of the side ports (the bottom is for drain back)
To use the pcv you use the rubber grommet in the top of the can and run a line to the intake manifold.
Or you can run it with the filter on the top instead of the pcv set up witch is how I run my set up.
here are some pics of both ways to use the top port. not the best sorry for the size
There was recently a post made about this, and I will like you too the proper setup, and too the link of the post.....
Proper Setup from Block to can = http://www.theoldone.com/artic...g.jpg
Link, which inturn has picture of the proper setup on that thread... https://honda-tech.com/zerothread?id=1034040
That should help perfectly.
petwhookie
69
Mar 12, 2010 03:50 PM
