Car grinds into third gear.
Old Dec 17, 2001 | 06:47 PM
sydag5's Avatar
Default Car grinds into third gear.
Whats up guys. My car grinds when shifting into third gear. It only does this when I am really on it, like shifting anywhere above 5000rpms it grinds and anything below that it doesn't. It only does this when shifting into 3rd. What do you guys think it could be? Any ideas would be helpful. Thanks.
Syd
Old Dec 17, 2001 | 06:51 PM
Tweakmeister's Avatar
Default Re: Car grinds into third gear. (sydag5)
Could be the synchros...what kind of milaege is on the transmission?
Have you have the fluid flushed recently? That might fix it.
Old Dec 17, 2001 | 07:26 PM
EightOhOne's Avatar
Default Re: Car grinds into third gear. (Tweakmeister)
probably the synchro....my 91 hatch grinds third when i shift to it fast..if i ease into it, its fine..sometimes
Old Dec 17, 2001 | 07:27 PM
rainforest's Avatar
oh yeah its a honda has to be the 3rd gear syncro they allways go.
Old Dec 17, 2001 | 09:27 PM
sydag5's Avatar
Default Re: Car grinds into third gear. (rainforest)
Yeah thats what i figured thanks for the info.
Old Dec 17, 2001 | 10:51 PM
Mista Bone's Avatar
D Tranny Guru
since your sig sez B16 on the way, that means your still running SOHC setup.
Third gear grind will likely be from worn motor/tranny mounts, if not the shifter fork inside the tranny.
Old Dec 18, 2001 | 12:16 AM
Katman's Avatar
cable tranny's = crappy grind problems.
Old Dec 18, 2001 | 02:29 AM
AfEn808's Avatar
New User
Default Re: Car grinds into third gear. (Katman)
jdm trannys are not worth rebuilding i would be easier and probably cheaper to just get another one and i dont see why a cable tranny would grind more than a hydraulic tranny, also i have a s1 with my b16 and its starting to grind the 3rd also all honda trannys suck there gonna grind eventually.
Old Dec 18, 2001 | 03:07 AM
rainforest's Avatar
Default Re: Car grinds into third gear. (AfEn808)
s1 are more prone to have 3rd gear syncros go. The y1 usually doesent have the same problem.
Old Dec 18, 2001 | 04:26 AM
Red Civic T's Avatar
New User
Welcome to the club! Does the gear at least get there or how bad is the grind.
On mine the 2-3 grinds, but I rip it off anyway but 1-2 won't even engage unless I take my foot (briefly) off the gas & worse as the revs climb so had to get sneady to get around the prob just a little bit.
I know everybody wants there $.02 in, but I would suggest going with Shockproof Ultralite Redline (70w0) for the tranny - that may be enough to help out on the grinds but gotta ask SPECIFICALLYfor it and not just regular Redline MTF fluid...
Old Dec 18, 2001 | 11:36 AM
Katman's Avatar
dont be a cynic...
Hydro trannies are designed a bit better than cable trannies. That's why they're a bit superior to the cable tranny. But, with cable tranny's, you'll have a better chance with YS1 rather than a Y1/S1/J1 tranny. The YS1 trannies uses a hydro trannies internal design (gears, synchros, diff, etc) but on a cable platform.
Old Dec 18, 2001 | 12:31 PM
Greyout's Avatar
Default Re: Car grinds into third gear. (Red Civic T)
I liked the royal purple tranny fluid. w/ the LSD additive
Old Dec 18, 2001 | 09:39 PM
clutch359's Avatar
From: somewhere between the motor and tranny, putting power to the wheels...
Default Re: Car grinds into third gear. (JDM LUDE)
im having the same problems. ive got a 95 ex coupe, on the upshift 2-3 grinds unless i let the rpms fall all the way and go EASILY into gear, and on downshift, 3-2 grinds really bad all the time no matter what. oh yeah, i dont have reverse either. and opinions? also, is the si tranny have different gear ratios (ie., should i go to that tranny instaead) or is it tha same as i have now? what trannysshould i look at to replace it or should i have it rebuilt? im also looking at putting in a phantom-grip limited slip unit in it. anyone had good or bad luck with these?
Old Dec 18, 2001 | 11:26 PM
chrisJ's Avatar
New User
Default Re: Car grinds into third gear. (clutch359)
some times when the motor is under load it moves and causes the tranny to grind when shifting. some friends had this problem at the track, the tranny would grind from 2 to 3. put a polyurethane busing in the rear mount and the problem went away. just another option
Old Dec 19, 2001 | 09:02 AM
allenp's Avatar
Do you have difficulty (i.e. - increased effort) going in to all gears?
Does your clutch "take up" and start to move the car with the pedal still very close to the floor?
If these are the case, then your clutch has lost some or all of its "reserve" and is no longer fully disengaging, even with the pedal on the floor. This would be likely due to the hydraulics leaking, or a bad cylinder (master or slave).
When your clutch loses reserve, your synchros have to work much harder than they should -- causing increased wear and premature failure.
[Modified by allenp, 6:03 PM 12/19/2001]
Old Dec 19, 2001 | 09:48 PM
Mista Bone's Avatar
D Tranny Guru
shifter fork worn or rear tranny mount loss. Do the ES insert on the rear mount ONLY if you want you fillings to stay in.
Old Dec 19, 2001 | 11:01 PM
civicturbo's Avatar
You might want to chk the topic "Trans pop's out of 2nd gear" from 12/20/2001.
98CivHx
Oct 25, 2006 10:05 PM
WhiteVX
May 19, 2006 04:37 PM
eg6turb0
14
Jan 9, 2005 10:07 AM
H2nr
Jul 12, 2004 08:52 PM
robbin
Oct 29, 2002 09:08 AM
