Solid cel on my chipped p28
Old Oct 17, 2004 | 09:39 PM
96MidoriHatch's Avatar
Default Solid cel on my chipped p28
I just got it all hooked up and im showing a solid cel. the ecu is a p28 chipped for uberdata with a gsr base map. I crossed the scc and all it does is light up solid. Does this mean the ecu is screwed?
Old Oct 18, 2004 | 03:39 AM
civic-4-ges's Avatar
Default Re: Solid cel on my chipped p28 (96MidoriHatch)
Does not neccessairly mean your ecu is screwed, could be a number of things
First off, double check all of you soldered connections.
If all is ok, then it could be an issue with Uberdata
version 1.7 Beta (1.67 I believe), has known to cause solid cel's even witha succesfully working map. Not sure why. You could try opening up the same .bin file you created for your basemap in version 1.65, and then resave it and burn from there.
If that does not work, then cut the jumper at J1, if you still get a solid cel, chances are your ecu is messed up.
Old Oct 18, 2004 | 08:44 AM
n1div's Avatar
are you running knock sensor?
Old Oct 18, 2004 | 08:50 AM
Default Re: (n1div)
No, p28's lack the electronics to monitor the knock sensor
Old Oct 18, 2004 | 11:11 AM
Default Re: (civic-4-ges)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1div &raquo;</TD></TR><TR><TD CLASS="quote">are you running knock sensor? </TD></TR></TABLE>
nope
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">No, p28's lack the electronics to monitor the knock sensor</TD></TR></TABLE>
yep
Old Oct 19, 2004 | 06:51 AM
n1div's Avatar
Exactly, and I see some people forget to disable the knock sensor when programming a chip, especially if they've taken a P30 or P72 map and forgot to turn it off.
Old Oct 19, 2004 | 08:30 AM
Default Re: (n1div)
Exactly, and I see some people forget to disable the knock sensor when programming a chip, especially if they've taken a P30 or P72 map and forgot to turn it off.</TD></TR></TABLE>
yea i have heard of that too, i disabled mine, but what happens if you dont? does it throw a knock sensor code?
elmejor
Jul 5, 2008 10:40 PM
huge230
May 8, 2006 08:49 AM
Stingray96
Oct 31, 2005 09:38 PM
Topdawgg
Aug 4, 2005 03:15 PM
