stock gsr + b16 tranny
Old Oct 17, 2004 | 08:47 PM
jdmsijdm's Avatar
Default stock gsr + b16 tranny
thinking about putting a b16 hydro tranny into an otherwise stock 95 gsr. What will this do to the gas mileage, cruising rpm, accelleration, top speed, etc. This tranny will bolt right up, right? no modifications required?
Old Oct 18, 2004 | 08:19 AM
Used2beAb16's Avatar
Default Re: stock gsr + b16 tranny (jdmsijdm)
You will notice a higher cruising rpm, not much change in gas mileage, unless you do 90% of your traveling on highways.
Top speed, well if the cars stock, its going to give the car better power in 5th gear because you have no where near the power/aero to max out a gsr tranny anyways.
You will also notice that your car will drop a couple tenths off the et.
91redteg
Aug 8, 2007 11:16 PM
whitehf
Mar 11, 2006 02:48 PM
db8geezer
Oct 18, 2005 12:21 PM
$$broke_db8
Dec 9, 2004 07:08 AM
SNS Performance
Oct 4, 2004 11:15 AM
