figure i'd get a better response in here for this sleeving question
Old Oct 17, 2004 | 07:30 PM
hatchblack's Avatar
Default figure i'd get a better response in here for this sleeving question
Can a block be resleeved to go 4 mm larger? or is that too large to try to resleeve it to? also, if that is possible to do, what would you use for a headgasket, or would the stock head gasket work, even though the cylinder walls are now 4 mm larger? any thoughts anyone?
Old Oct 18, 2004 | 03:13 AM
hondaguyef's Avatar
Default Re: figure i'd get a better response in here for this sleeving question (hatchblack)
I have seen blocks sleeved up to 85mm. Cometic, Golden eagle and a few other companies make headgaskets especially for larger bores sizes. I beleive GE uses OEM gaskets and bores them to what ever size you need.
check em' out : Golden Eagle Mfg.
Phil
Old Oct 18, 2004 | 05:09 PM
PrettyLude's Avatar
why would you want to bore it out that big, you don't wanna leave any room incase of errors or boring later down the road?
Old Oct 18, 2004 | 06:40 PM
hatchblack's Avatar
Default Re: (PrettyLude)
it's more or less for convenience then because i want to go that big - i have a motor that has an 83 mm bore and i can use rods from another motor because they are the same, and i could use those pistons too if i can resleeve and have that big of a bore on the motor, which is 87mm. if i can't go that big, then i would spend the extra money to get some custom pistons made, but i think that would be more expensive - i haven't looked into that too much yet, i was just checking my options first.
team_lunatics
Apr 11, 2011 08:01 PM
btech
Sep 2, 2006 09:08 AM
Appleton21
Aug 31, 2005 10:02 AM
Turbocivic94
Apr 25, 2005 06:21 PM
Flamenco-T
Jan 16, 2002 10:09 PM
