anybody running a 2 layer stock headgasket?
Old Oct 17, 2004 | 03:44 PM
91integraLSVTEC's Avatar
Default anybody running a 2 layer stock headgasket?
bent some valves in my itr motor. going to replace it with the head i had on my ls/vtec.. i want more compression, i was thinking about milling the head 0.010 and removing the middle layer of the headgasket. just wanted to know from the people that has done this mod had any problems? thanks in advance
Old Oct 17, 2004 | 04:14 PM
johnzm's Avatar
Default Re: anybody running a 2 layer stock headgasket? (91integraLSVTEC)
i removed the middle layer. go ahead and do it. no leaks no problems for 5000 miles so far
Old Oct 17, 2004 | 05:02 PM
drdisco69's Avatar
Default Re: anybody running a 2 layer stock headgasket? (johnzm)
There has been confusion as to how to remove a layer. Risking a flaming for not searching, could you tell us how? Are the dowel pins sufficent to align it?
Old Nov 26, 2004 | 01:07 AM
Mike@K-Tuned's Avatar
Just wondering how you took out the middle layer. I've heard it is easy enough just remove the copper rings remove the middle silver layer and use the other to pieces. Is this all you did on yours? I'm considering this option instead of milling my cylinder head. Also anyone have any pics?
Old Nov 26, 2004 | 04:36 AM
johnzm's Avatar
Default Re: anybody running a 2 layer stock headgasket? (EGgsrAM)
thats all i did. the little copper rings that hold it together are pretty soft, and come out easily. ull the layers apart and pull the silver one out. i copper sprayed mine.
Old Nov 26, 2004 | 08:48 AM
hybridnorth's Avatar
make sure your hands are clean, and the needle nose pliers are in good shape
just pry up the sides of the copper ring, its super soft, remove middle layer and install it like you would any other head gasket
Old Nov 26, 2004 | 01:01 PM
Tbone's Avatar
I ran jdm itr 11.1 cr pistons in my itr motor with a 2 layer gasket and toda b cams.. Never had any issues with valve to piston at all.
I've removed the top layer and also the middle on different motors.(not at the same time )
Old Nov 26, 2004 | 02:28 PM
hybrid_vtec's Avatar
Default Re: anybody running a 2 layer stock headgasket? (hybridnorth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridnorth &raquo;</TD></TR><TR><TD CLASS="quote">make sure your hands are clean, and the needle nose pliers are in good shape
just pry up the sides of the copper ring, its super soft, remove middle layer and install it like you would any other head gasket</TD></TR></TABLE>
Pretty much it, it's not brain surgery or anything! Just make sure you use new Head studs and lube them before you put them in and torque them down! Use the proper pattern, torque in a 2-step method to the right specs and you should be good!
zboog929
Oct 1, 2010 06:06 AM
trooper0641
Mar 24, 2010 10:12 AM
the.hamburglar
Jun 10, 2006 02:17 PM
NACvicSi
Oct 23, 2005 04:36 PM
vspec12
Mar 27, 2004 09:10 PM
