need to know what comp housing is interchangable with this
Old Oct 17, 2004 | 11:48 AM
Prelude91siT's Avatar
Default need to know what comp housing is interchangable with this
would like to know what better comp housing i could put on this and is it as easy as just un bolting the one and replacing it with the new one? any info would be greatly appreciated. thanks
Old Oct 17, 2004 | 12:56 PM
biizzump
Old Oct 17, 2004 | 01:59 PM
Bailhatch's Avatar
Default Re: (Prelude91siT)
that looks like a 60 trim T3 wheel so you can swap it with any cover made for a 60 trim t3 compressor.
Why would you want to change it? The .60 A/R one is the biggest I have seen.
Do you want to swap it for the slip fit connections? If so, I have a 60 trim cover that isn't flanged like that one you could have.
Old Oct 17, 2004 | 06:27 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Bailhatch)
the nissan t3 cover is a 60trim .60ar housing. its on my t3
Old Oct 18, 2004 | 02:08 PM
can anybody tellme anything else about this turbo. so this is actually a .60 trim. even though this is a t3 is this bigger than like a t3/t4e with a 57 trim. also it has a .63 a/r exhaust
Old Oct 18, 2004 | 02:24 PM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude91siT &raquo;</TD></TR><TR><TD CLASS="quote">can anybody tellme anything else about this turbo. so this is actually a .60 trim. even though this is a t3 is this bigger than like a t3/t4e with a 57 trim. also it has a .63 a/r exhaust</TD></TR></TABLE>
No, it's a T3 60 trim, not a TO4E 60 trim, 2 totally different wheels.
Old Oct 18, 2004 | 03:27 PM
i know this but is it bigger than like like a t3/t4 with a 57 trim
Old Oct 18, 2004 | 03:41 PM
Sonny's Avatar
No, the T04E stuff is all bigger than the 60 trim T3.
Sonny
Old Oct 18, 2004 | 06:09 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Sonny)
t3 compressor housing vs. a t4 compressor housing.
Old Oct 19, 2004 | 06:40 AM
so if i got a t3 .60 trim compressor that would be smaller than a t4 .50 trim comp?
Old Oct 19, 2004 | 06:44 AM
also what the max whp is this turbo capable of making on a like a b18b or b20? it has a .63 exhaust and as it says a .60 comp
Old Oct 19, 2004 | 11:17 AM
hey hey
Old Oct 19, 2004 | 11:27 AM
stackz's Avatar
at the jetties fishin'
Community Builder
that turbo (well at least that compressor housing) is from a ford 2.3 turbo engine. They had two offered. Both with .60 cold side.
automatic cars had a .48 hot side and manuals had a .63 hot side.
These turbos are good to about 20~22psi before they start to lose efficiency (though this is only when bolted to a ford 2.3 turbo engine). early ones were oil cooled only and later ones were oil/water cooled.
Old Oct 19, 2004 | 11:47 AM
yeah this has a 5 bolt exhaust with a .63 hot side. would this be a good choose for like a built h23 just with a smaller bore of like 84mm. i have a built b20a which is similiar to a h23 except the h23 has a bigger bore. but we use the same rods. again thanks
.PLUMMM
Nov 23, 2007 02:30 PM
Mugencrxsir1
May 17, 2006 02:56 PM
mrx
Sep 3, 2005 11:27 AM
Lucky_Smurf
Jan 11, 2005 04:37 PM
Ri5e
Aug 24, 2001 07:59 AM
