priming oil pressure for first startup
Old Oct 17, 2004 | 11:47 AM
96MidoriHatch's Avatar
Default priming oil pressure for first startup
just went through a rebuild and im about to start it up but i have heard that u need to prime it to build oil pressure. Do i need to do that? and if i do how do you guys do it?
Old Oct 17, 2004 | 11:52 AM
krazie1's Avatar
BANNED
Default Re: priming oil pressure for first startup (96MidoriHatch)
disconnect the coil or the plug wires from the dizzy and u can do this as it won't let it crank over
and if u worried about fuel priming too then dissconnect the fuel pump and there u go nothing but oil will be cycling
Old Oct 17, 2004 | 12:20 PM
DeuelOrDie's Avatar
or you could be really cool and buy an Oil accumulator, which holds about 2 quarts of oil, is pressurised with about 100psi. all you do is hit the selenoid switch, and BAM you got O P. Moroso is the only maker that I know of, but if your real smart it be an easy DIY!!
Old Oct 17, 2004 | 04:29 PM
Default Re: priming oil pressure for first startup (DeuelOrDie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 &raquo;</TD></TR><TR><TD CLASS="quote">
and if u worried about fuel priming too then dissconnect the fuel pump and there u go nothing but oil will be cycling</TD></TR></TABLE>
can i just unplug the injectors? and if i do have to disconnect the fuel pump isnt there a fuse i can just unplug?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeuelOrDie &raquo;</TD></TR><TR><TD CLASS="quote">or you could be really cool and buy an Oil accumulator, which holds about 2 quarts of oil, is pressurised with about 100psi. all you do is hit the selenoid switch, and BAM you got O P. Moroso is the only maker that I know of, but if your real smart it be an easy DIY!!</TD></TR></TABLE>
that sounds cool i'll look into that too but on this motor i dont have time
Old Oct 17, 2004 | 05:51 PM
IN VTEC's Avatar
The oil accumulators from Moroso and Accusump need to have pressurized oil pumped into them first before they can be used for pre-oiling before start up.
You would have to install the accumulator on another car temporarily to fill it with pressurized oil.
Remove the 15A ECU fuse to crank the motor w/o fuel or spark.
Old Oct 17, 2004 | 06:05 PM
Default Re: priming oil pressure for first startup (IN VTEC)
is that the fuse that says FI/em? its on a 96 civic dx
Old Oct 17, 2004 | 06:31 PM
92-LS-Civic's Avatar
i have a 92 civic hb, putting in a b18b1, so just unpluging the distrib will work? should i disconnect fuel injectors?
Old Oct 17, 2004 | 07:00 PM
Steve91's Avatar
Default Re: priming oil pressure for first startup (zdowell17)
pull the spark plugs too. This allows the motor to spin freely. I also recommend you pour some oil down the pickup tube while the engine is upside down on the engine stand. This gets the pump gears wet and allows them to make suction right away.
Old Oct 17, 2004 | 07:37 PM
DeuelOrDie's Avatar
I wish I could go and jsut buy some pressurized oil!
All you need to have is an air hose to pressurize the ACCUMULATOR.
But if you want to real cool just buy a 12v small compressor and you have "pressurized oil" where ever you go!
Old Oct 17, 2004 | 08:48 PM
thanx for the info everyone. so is that fuse that says FI EM the one you are talking about IN VTEC?
Old Oct 17, 2004 | 09:19 PM
Kamin's Avatar
wow thats alot more pressure than the pump makes, ever think about what that does to seals?
dont do the disconnect distributor method, the engine is still dry spinning when you crank it.
the BEST way to do it is this way. go to home depot, get one of those hand pump bug sprayers, get a fitting that fits into the oil pressure sender threaded hole. (autozone will sell them if you bring them the OP sender to compare thread size) and just connect the bug sprayer to that fitting. put 2 quarts of oil in the sprayer and just start pumping. when the 2 quarts are in the engine, its gotten enough oil all around the oiling system.
Old Oct 17, 2004 | 09:50 PM
IN VTEC's Avatar
I don't know how it's labeled on the Civic's, but on my Integra, it's labeled "ECU".
You could also disconnect the ECU from the harness.
I was wrong about needing to fill the accumulators with pressurized oil rather than pressurizing it after filling it with oil. You really only need to pressurize it with 50psi of air to be sufficient. I remember why I have one now.
I like the hand pump idea, but wouldn't you need a check valve on the line to keep the oil from backflowing?
Old Oct 17, 2004 | 10:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
are you sure? i mean its not like there is no assembly lube in there or something, but then again how long do i have to crank it to build enough pressure?
Old Oct 18, 2004 | 11:12 AM
bump for more info
Old Oct 18, 2004 | 01:00 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96MidoriHatch &raquo;</TD></TR><TR><TD CLASS="quote">are you sure? i mean its not like there is no assembly lube in there or something, but then again how long do i have to crank it to build enough pressure? </TD></TR></TABLE>
im telling you the 100% sure fire safe way to do it. even with assy. lube there is a SLIGHT chance you can spin a bearing. i cant count how many engine i myself have dry cranked to prime and never had a problem, but the SAFEST way is the bug sprayer. its cheap and why even take the chance?
and you should realy have an oil pressure gauge so you know if you are even building pressure.
Old Oct 18, 2004 | 02:50 PM
Default Re: priming oil pressure for first startup (Kamin)
and you should realy have an oil pressure gauge so you know if you are even building pressure. </TD></TR></TABLE>
i think i will do that i just didnt want to end up having to pull the sensor back out because the motor is already in the car
GoldLudeRay
Feb 10, 2009 07:04 AM
fr3dy_1
17
May 23, 2008 11:33 PM
crxsiperf
Nov 23, 2005 04:36 PM
hybrid_vtec
24
Sep 27, 2004 10:18 AM
smeister
Oct 1, 2002 03:22 AM
