car sounds like it has a flat/dragging but tires are fine
Old Oct 17, 2004 | 10:50 AM
Gant's Avatar
Default car sounds like it has a flat/dragging but tires are fine
i tried searching but serach it out right now says "please try again later"
when driving home i got off the freeway i had my windows open and noticed the car sounded like it had a flat so i get home and i look at all the tires and nothing is flat what could this noise be?
Old Oct 17, 2004 | 10:54 AM
S9i1R's Avatar
Default Re: car sounds like it has a flat/dragging but tires are fine (Ba4)
body parts or something might be dragging, check your wheel well covers
Old Oct 17, 2004 | 10:57 AM
FairlightRacing's Avatar
Wheel bearings. They are probally going bad. Make sure the 32mm axle bolt is tight as well (the gold one you see when the little lug-nut cover is off. assuming you have 90+ Si wheels).
Could also be an impact break. Inspect your tires for a "bubble." That is an impact break and can cause the noise along with making the car pull to one side depending on bad it is.
Old Oct 17, 2004 | 11:02 AM
Gant's Avatar
sigh i was hoping its not wheel bearings :/ i changed my lug stud at work and just pounded it out/used a impact gun on it that prolly fucked the wheel bearing up
i dont know i hope its the tires cuase it just happen all of a sudden as soon as i got off the freeway about a mile or two away from my house i could here it, wheel bearings are a bitch :/ good thing i work at a delaership we should have a press to press it out and such but iono if we have all the tools cuase its a Gm dealership
Old Oct 17, 2004 | 11:27 AM
Gant's Avatar
alright just drove it when i was next to a barrier u could here this silght kidna sounds like a nail in the tire but real loud, no flat sound yet, then decided to drive it around more and then all of a sudden bam the LOUD dragging sound comes on, so i drive real slow its still real loud , i come to a turn i pull a uturn to go to my house and the noise dissapers :/ is this the sign of a wheel bearing? or something else?, jeez i wish search was back !~!!!!!
Old Oct 17, 2004 | 11:30 AM
ef8 h0!'s Avatar
Default Re: car sounds like it has a flat/dragging but tires are fine (FairlightRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FairlightRacing &raquo;</TD></TR><TR><TD CLASS="quote">Wheel bearings. They are probally going bad. Make sure the 32mm axle bolt is tight as well (the gold one you see when the little lug-nut cover is off. assuming you have 90+ Si wheels).
Could also be an impact break. Inspect your tires for a "bubble." That is an impact break and can cause the noise along with making the car pull to one side depending on bad it is.</TD></TR></TABLE>
ya, what he said!
Old Oct 17, 2004 | 11:31 AM
Gant's Avatar
uh ok
Old Oct 17, 2004 | 11:33 AM
Gant's Avatar
Default Re: (Ba4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">alright just drove it when i was next to a barrier u could here this silght kidna sounds like a nail in the tire but real loud, no flat sound yet, then decided to drive it around more and then all of a sudden bam the LOUD dragging sound comes on, so i drive real slow its still real loud , i come to a turn i pull a uturn to go to my house and the noise dissapers :/ is this the sign of a wheel bearing? or something else?, jeez i wish search was back !~!!!!!</TD></TR></TABLE>
sigh i wish search was working wtf is up with the damn search ugh
Old Oct 17, 2004 | 11:55 AM
Gant's Avatar
is there anyway to check the wheel bearing/test it?
Old Oct 17, 2004 | 12:05 PM
Sobe_Death's Avatar
jack up the car, when the wheels no longer touch make sure the parking brake is off and wiggle the wheels back/forth then up/down. if it has play in any wheel, then your bearing is dying.
Old Oct 17, 2004 | 12:06 PM
Gant's Avatar
Default Re: car sounds like it has a flat/dragging but tires are fine (Sobe_Death)
stupid question but i dont remember do the rear wheels have wheel bearings?
Old Oct 17, 2004 | 12:19 PM
Sobe_Death's Avatar
yes they all do
Old Oct 17, 2004 | 12:31 PM
Gant's Avatar
what would be the cause of the flat tire/dragging noise to go away? its wierd cuase when i drove it earlier it just started making the loud noise again then when i pulled a uturn to go back to my house it went away :/
Elvis1977
11
Nov 12, 2012 04:46 PM
JDMcivic801
Jul 30, 2010 10:56 AM
streetglow116
Apr 17, 2009 08:57 AM
honda_k20a
Dec 18, 2008 05:25 AM
Saintor
Apr 29, 2004 10:28 PM
