p72 or p28?????
Old Oct 17, 2004 | 07:07 AM
b00sted4dr's Avatar
Default p72 or p28?????
I will be converting my obd2 to obd1 and i needed to know what ecu should i run...
My situation....
I have a gsr with stock gsr IM and will be putting ctr cams in. I want to raise my vtec crossover and raise my fuel cutoff. I not sure what i want to do with the IM yet, either get a skunk2 or just port my gsr IM.
Which comes to my question now.....
I am i better off with a p72 or p28?
Or it doesnt matter?
Old Oct 17, 2004 | 08:16 AM
toolowsol's Avatar
Default Re: p72 or p28????? (That4drGSR)
If you keeping the stock IM go with a p72, if you are getting an aftermarket IM go with whatever is cheaper (usually p28 and get it chipped)
I socket ECU's for $50 shipped so keep that in mind when looking for a ecu. If you can get a 28 ecu for more than $50 cheaper than p72, stick with that
Old Oct 17, 2004 | 08:31 AM
b00sted4dr's Avatar
Default Re: p72 or p28????? (toolowsol)
So if i socket the p28 i can run it with the gsr IM?
Old Oct 17, 2004 | 08:53 AM
toolowsol's Avatar
You can, but your secondaries wont work, that is why I said, if you have the GSR IM go with the p72 ecu.
Old Oct 17, 2004 | 09:04 AM
b00sted4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">You can, but your secondaries wont work, that is why I said, if you have the GSR IM go with the p72 ecu.</TD></TR></TABLE>
Good stuff.
Anyway to disable secondaries with the p72?
Old Oct 17, 2004 | 11:09 AM
toolowsol's Avatar
unplug them, remove them, or buy a new intake manifold. But if you have the GSR intake manifold, keep them, they are good for flatening your torque curve.
grant90
Nov 1, 2010 10:25 AM
93bubble87
Engine Management and Tuning
11
Jan 5, 2010 07:59 PM
mesonerz
Oct 1, 2007 08:23 PM
Zion-I
Feb 12, 2006 09:32 PM
vizsual00
18
Oct 23, 2003 02:33 PM
